Old 04-10-2002, 12:08 PM   #1
dwitkirb
Angry 1996 Lumina Intermittent Overheating
My 1996 Lumina temperature gauge runs hot and then cools down within a minute, over and over and over. Supposedly all external problems have been eliminated. Our Chevy Dealer said they need to tear down the engine because the problem is internal. The car runs fine, with no other problems other than the temperature swings.
Can you help?
dwitkirb is offline   Reply With Quote
Old 05-03-2002, 11:03 AM   #2
Nofear1049
The Chevy Dealer Is Right Because It Is Headgasket Or Value Cover Gasket That Has Gone Bad On The Engine On The Lumina
Nofear1049 is offline   Reply With Quote
Old 08-08-2002, 06:55 PM   #3
Lumina95
Unhappy
I have the same problem with my '95 Lumina. After some time of driving the temperature would go up to 3/4. I flushed the radiator, put new coolant and that didn't do anything. Then I put a new temperature sensor and I got all the engine power back. Probably the computer is convinced now that it is actually not overheating . The gage still goes up but comes down again, at least sometimes. Occasionally I also get a Service Engine soon but the Diagnostic System doesn't let me pull any code! Its simply not working. Is the PCM to blame? What can I do?
Lumina95 is offline   Reply With Quote
Old 09-20-2002, 04:02 PM   #4
cgin59
If it's a 3.1 L engine, here's my advice....
1) Make sure all excess air is removed from the cooling system. There is a bleeder screw on the water outlet and on the pipe coming out of the pump. I used a vacuum pump to suck all the air out of the lines at the bleeder screws....until the pump started sucking antifreeze.
2) Make sure the electric fans are working properly. If the #1 fan doesn't come or comes on late, the car will over heat. Fan #2 is a backup and only comes on when the engine overheats.
If there is something internally wrong with the engine, it will show up in more than one place. I doubt there is an internal engine problem with just overheating!!!
cgin59 is offline   Reply With Quote
Old 11-15-2003, 10:37 PM   #5
DrivinTooFast
Re: 1996 Lumina Intermittent Overheating
You could always replace the thermostst, but assuming all the "external" repairs were made they did that already. just a suggestion
DrivinTooFast is offline   Reply With Quote
Old 12-09-2003, 06:58 PM   #6
ja_miller
Lumina temperature Problems
This is a little late for the original post but may be helpful for someone else.
I had expirienced alot of the same things seen in this post. There is one additional repair step I took.
I ended up taking my radiator out of the vehicle and had it rotted out at a radiator repair center. After reinstalling it and making sure the air was purged from the engine cooling system, the problem went away and has not come back.
This was after replacing several thermostats and a blown head gasket.
Hope this helps someone in need!
ja_miller is offline   Reply With Quote
