Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV
Old 11-22-2001, 02:12 PM
kyle95g20 kyle95g20 is offline
how much money will this take from me and how much power will i get from it?
i work at a car dealership and encounter lots of cars that i can aquire for dirt cheap. a person recently traded in their 88 civic dx hatchback(5 spd not the shitty 4 spd) and i can buy it for 300 dollars. this car is slow and i don't want that. what i would like to do is build a frankenstein b series motor but since i owna nan infiniti i really only know nissans. the motor i have in mind is the b20(crv) block and internals exc. the crank. i would source the crank from a b17(1st gen gsr) and the head froma b16. the reasoning i would like to do this is i want the 2 liter's displacement, the 1.7's wind up and the bullet proof head of the 1.6. i have been told that all/most b series components are compatible with eachother so i figure this will work. but as the topic stated how much power will i get and how much money will it cost me?
gone through so many cars i can't keep track. all i know is i have a gsr swap on the floor of the garage that is going in a teal boxy hatch.
Old 11-22-2001, 04:21 PM
JD@af's Avatar
JD@af JD@af is offline
Missing in action
Send a message via ICQ to JD@af Send a message via AIM to JD@af
That's a sweet plan, kyle. I don't really know about that plan, i.e. how much power it will get you.. but I'd think that you should be able to get in the neighborhood of 200 horsepower to the crank (without much trouble ). It will cost you some. You will ideally want custom pistons and rods (let me know if you need a good source for these), which should cost you perhaps $1K to $1,200, the block should cost you a little over a grand, the head should be anywhere from $500 to $800 (I'd recommend the B18C head as well, though it will probably cost you a little more than a B16 head) and the crank you may be looking at about $300 to get your hands on one. It's not a cheap plan, but doing it the right way usually will cost you. I have to check a guide on swapping (which I unfortunately don't have with me), but you may need an aftermarket mounting kit to put a B series into your new Civic.
Old 12-05-2001, 02:59 AM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
all i gotta say is that would be a beast if it ever works out good lluck
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 12-07-2001, 12:43 AM
pvang31019 pvang31019 is offline
Re: how much money will this take from me and how much power will i get from it?
great idea bro, that civic HB will fly...but here's some stuff you should think about..
1. The b20 is the perfect candidate, but don't get the 1.7 crank. THe only reason to get the crank is for destroking it to 1.8L and getting a near perfect r/s ratio for turbocharging....That would destroy the point of a 2.0L vtec motor, trust me, the b20 r/s ratio is not as bad as people think( it's bad, but the block can handle more than you think)...
2. get some vtec pistons(OEM has none, so either get some JE's or Wiseco)...might as well bump that compression while you're at it.
3. at least shotpeen your rods for continuous 8000rpm usage.
4. if built right, you can make 200+whp with good aftermarket cams...
Old 12-07-2001, 12:49 AM
madtownhonda's Avatar
madtownhonda madtownhonda is offline
Send a message via AIM to madtownhonda
what dealer do you work at in Madison you can get cars for that cheap....can you hook me up, I need a winter beater
