Old 09-04-2003, 10:57 AM   #1
Dip32
92Corsica 3.1L Hard starting.....183k miles
Cranks for bout 5 secs before firing up, then revs way up for another 5 secs before idling down. Does the same thing warm or cold, not displaying any ecm codes, surges at stoplights once in awhile, irratic idle once it get hot..up down 100/200rpm's, rough idle, and gets craip for gas mileage. Changed the tps and idle control valve..no luck. Anyone know where to look next?
p.s The car was in a small accident right before i purchased it as a fixer upper. Front end collision, i replaced bumper and headlights but air bag never went off. Possibly a bad ecu from the impact?
Any suggestions would be awesome!
Thnx Joe
Dip32 is offline   Reply With Quote
Old 09-04-2003, 06:04 PM   #2
pcv
Scan the system and check the reading of the coolant sensor, tps and iac valve. The should be within specs, if not the vehicle will be hunting ( revving up and down). Also try cleaning the throtlebody with a good cleaner. Good Luck.
NOTHING LIKE AN OLD CAR.
pcv is offline   Reply With Quote
Old 09-05-2003, 04:03 AM   #3
Dip32
Re: 92Corsica 3.1L Hard starting.....183k miles
Where do i find the specs to check the sensors? And the throttle body is filthy!
Old 09-05-2003, 04:55 PM   #4
pcv
Specs are available from books like Haynes and Mitchell and I'm sure its available on line too but I havn't looked there. With the vehicle running the tps should be between .54 and.68 volts. Adjustments are possible but it whould be left to a trained tech. Adjusting one item, affects other sensors. Clean the throtlebody for now and see how it goes.
