Go Back   Automotive Forums .com Car Chat > Buick > Regal
Old 11-04-2002, 07:25 PM   #1
sualohcin
Supercharging a 1994 Regal 3.8L
I have a 1994 Buick Regal with a 3.8L (non-supercharged). I was wondering if a supercharger from another buick, pontiac, etc. would work on my car? If anyone could help me out it would be greatly appreciated! thanks!
sualohcin is offline   Reply With Quote
Old 11-22-2002, 12:58 AM   #2
Alaskan_Ranger
hmm try checking out a wrecked one. ( super charged) im sure if you took evry thing off of a wrecked car that it should work....atleast i dont see why not.
Charlie
Alaskan_Ranger is offline   Reply With Quote
Old 06-21-2003, 02:52 PM   #3
caddymac
Send a message via AIM to caddymac
Your best bet would be to install an L67/4T65HDe and PCM from a wrecked 1997-current Regal or GTP. More information on this swap can be found at www.L67swap.com
caddymac is offline   Reply With Quote
Old 06-23-2003, 07:45 AM   #4
GM Ross
Lightbulb FWD S/C
You have what's known as a 3800 Series I engine, this version was in use from 1991 thru 1995. GM offered two different S/C's '92-93 and '94-95 that should be a direct bolt-on. It's necessary to change the Harmonic balancer pulley (2 belts), all the accessory brackets (relocated power steering pump and Alternator) and the complete intake manifold. And wiring harness mods.
To manage the Boost you'll need a compatible ECM/ PCM, probably the Bonneville and to provide the expanded Fuel/ Air Charts to run it. Then there's intake air capacity, then there's exhaust capacity...
I'm working on escentially the same upgrade, I have an'88 Reatta which now has the Series I engine installed last Fall with a manual transmission. This next week will be transplantinga '94-95 S/C.
I'm fortunate to have an acquaintance who's capable of doing the PROM reprogramming that's necessary to keep all my electronics happy with modifications.
Greg Ross
!988 Buick(the Two Seater)
Reatta
Getrag 5-Spd.
3800 Series I
Mildly Juiced Crane Cam
S/C this Week if I'm lucky
GM Ross is offline   Reply With Quote
Old 08-25-2003, 07:29 PM   #5
Hypsi87
I got your v-8 swingin!!!
Hypsi87's Avatar
Send a message via AIM to Hypsi87
im not to shure on the new supercharged ones but in the GN the compression raito was dropped from 9to 1 to 8 to1 to handle the compressed air when boost was beig applied. so check to make shure that you won't run into problems or your crank will look like this (follow link) http://home.earthlink.net/~lstsimpson/. it is not pretty at all. also check that your crank and pistons and connecting rods are going to hold together under boost. putting a motor under boost is not just a bolt on thing (that is if you don't wanna be picking up pieces a few months down the road) so make shre you have all the facts. Im not saying all of this is true im more of a GN turbo guy i don't really know much about the new supercharged motors but boost is boost just don't wanna see you blow something up
Andy
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Hypsi87 is offline   Reply With Quote
