Old 08-06-2003, 05:19 PM   #1
euroAccorDeuro
Anybody else had this brake problem?
My brakes are horrible right now, when i hit them, i have to push them to the floor. Also, the wheel turns to the left. I was planning on just bleeding the brake lines, even though ive never done it. Any suggestions on what it could be or what i should do about it? Thanks.
euroAccorDeuro is offline   Reply With Quote
Old 08-06-2003, 07:06 PM   #2
Plastic_Fork
Plastic_Fork's Avatar
Bleeding the brakes might help if you have air in the lines which would cause more play in the brake pedal. Also check your pads to see how worn they are -- that could also require more pedal for them to make contact on the rotor. And if your car is pulling when braking, check your alignment / balance and also see if your brake rotors are warped. Honda car rotors are thinner than others, so they tend to warp more often.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Plastic_Fork is offline   Reply With Quote
Old 08-07-2003, 01:44 AM   #3
vik
Send a message via AIM to vik
i had the exact same problem. i had to get my master cylinder replaced.
1998 Mustang GT (Black)
MAC CAI
Flowmasters
2 12's JL Audio W3's
Pioneer DEH-P4500 (Deck)
MB Quart Speakers (4)
Crunch Amp (Speakers)
HiFonics Amp (Subs)
Solid Audio Tweeters
XM Radio
vik is offline   Reply With Quote
Old 08-07-2003, 12:48 PM   #4
euroAccorDeuro
Well i checked the pads, they didnt look too worn. But i think it is a problem with the brake fluid. Because if you take your foot of the brake(after u push it to the floor), and push it again, it seems easier, like i dont have to push as far. That was what threw me off. Any other suggestions. Also, it didnt happen gradually. It just seemed like one day they worked fine, the next day i had all these problems. Thanks for the help.
Old 08-07-2003, 12:54 PM   #5
y2knowledge
It's funny, I have that same problem right now too and whenever I had my tires rotated I tried to check out my brakes. They looked fine and I had no clue why they would act up. Hopefully bleading your breaks will help you out! I'll have to get mine done to see if that remedies my problem...
y2knowledge is offline   Reply With Quote
Old 08-07-2003, 01:34 PM   #6
micheal
Send a message via AIM to micheal
bleed em. sounds like u got gush in the m-cylinder.
u wouldn't happen to be running directional tires would you?
micheal is offline   Reply With Quote
Old 08-07-2003, 01:45 PM   #7
euroAccorDeuro
I do have wheel spacers on.....
I'm taking em off in about a month when i get my 18's
Has anyone else had this wacky problem? Polaroo Grand Cherokee | Grand Cherokee SRT8 7 04-04-2017 08:58 PM
Has anybody else had this problem?? ruberpoliceman Caprice 4 12-09-2005 08:11 PM
Anybody else have this problem - Harmonic Balancer vengebear Grand Prix 3 01-05-2005 02:15 AM
Has anyone else had this problem? blues02TA Camaro Discussions 2 11-05-2003 12:54 AM
has anyone else had this problem w/their 93? Zoebe Diamante 2 10-20-2003 12:50 PM
