Register FAQ Social Groups
Old 12-14-2003, 12:35 PM
b16rex b16rex is offline
Send a message via MSN to b16rex Send a message via Yahoo to b16rex
Missed 4th while spraying :screwy:
Well I was seeing how much my 50 shot was going to help me so I went out on a country road and tested it out. The first time I spun through first so it didnt' work out very well. The second time I didn't engage it until the end of first. It feels a lot more powerful, well it did. I was in third and at about 8000 rpms I went to shift but missed and I just heard the engine rev up and hit the limiter. I eventually got it into 4th but it just started shaking. Then I tried the other gears and it shook to. I pulled it over and had it towed to my mechanic. He said I might have floated the valves and bent one....or possibly messed up the pistons and some other stuff. Anyone have any other ideas on what it might be??? I really need your guys help....please!
-1994 Civic coupe DX
Old 12-14-2003, 12:41 PM
SiZ's Avatar
SiZ SiZ is offline
Re: Missed 4th while spraying :screwy:
You shouldn't float a valve from just hitting the rev limiter..
Did you put it in a lower gear than it should have been in?!
"The nympho of info, I'm fuckin' what ya heard"
Old 12-14-2003, 12:44 PM
No the gears were the same. So your saying if I was using a 50 shot it shouldn't have floated the valves??? What else could it be??
Old 12-14-2003, 02:06 PM
BullShifter's Avatar
BullShifter BullShifter is offline
Good job, How do you miss 4th? I rarely spray in 1st, if so its at the higher RPM. I also make sure the juice is off when shifting to prevent an over-rev in the case of a missed gear. When I miss a gear is usually 3rd. You could have easily bent valves or cracked holes in the pistons.
If it were my car, the head would come off right away. Better safe than sorry.
Sorry to hear that, what it was only the first couple hits before you goofed? Now you have a reason to build a Nitrous motor. My buddy just toasted his ZC sohc(built for N20), he was spraying a 75 shot with 5-6psi of boost.
Old 12-14-2003, 04:17 PM
91civicDXdude's Avatar
91civicDXdude 91civicDXdude is offline
Send a message via MSN to 91civicDXdude
what are you doing spraying while shifting anyways?
What makes you think you should be spoonfed?
http://4thgencivic0.tripod.com
Old 12-14-2003, 04:19 PM
Yeah I only had it for a day and a half Yeah I know I'm a dumbass. Well hopefully the pistons are okay. If not what kind of pistons should I get that can take nitrous without breaking? What else should I get while everyhting is apart?
Old 12-14-2003, 04:22 PM
So all of you guys turn it off when shifting??? Even when it's on throttle?
Old 12-14-2003, 07:30 PM
You should release the gas while shifting
Old 12-14-2003, 08:00 PM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
I can't wait to get my nos
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 12-14-2003, 08:13 PM
http://store.summitracing.com/partde...art=SAD%2DSA73
Old 12-14-2003, 08:27 PM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
run a compression test
i have a 91 Civic DX with 3x as much money in it as what i paid for it
i wish it was fast
here is my website
http://www.geocities.com/krustindumm/index.htm
Old 12-14-2003, 08:56 PM
lowlife4life lowlife4life is offline
Send a message via AIM to lowlife4life Send a message via Yahoo to lowlife4life
i bet you bent a piston rod. you were probably putting too much power to the stock block of the honda. and when you missed the shift it was able to reach the max. power of your engine, while the bottom end remains stock.
just be glad you didnt throw a rod and blow a bigass hole in yo block.
lesson learned? learn how to drive before you start playin w/ nitrous or forced induction.
Old 12-20-2003, 03:40 PM
D15Bitch's Avatar
D15Bitch D15Bitch is offline
You guys might laugh at me, but this is exactly why I stick to an autobox...
Old 12-20-2003, 04:48 PM
88CRX's Avatar
88CRX 88CRX is offline
cause mr.b16rex cant drive?
I was also in your state of mind.... then i got my zc and converted over to a 5 speed. Fuck was i ever dumb for ever thinking an auto was even decent
As long as you can drive and are RESPONSIBLE about your nawz yo! then youll be just fine.
zc powa
short ram intake
dc sports header
2.25 Magnaflow exhaust
h/r race springs
Old 12-20-2003, 05:18 PM
D15Bitch's Avatar
Re: Re: Missed 4th while spraying :screwy:
I don't know if this means anything, but the autobox I have is the same box (JDM) that was put in 4th gen civics in Japan with the SOHC ZC engine (120HP). I have noticed it has quicker 1st and second than the old autobox I had which was mated to my D15... Does anyone know if there is a definite difference between these boxes...?
I have also noticed that Nissan Sentra 200STi's and Golf GTI's cannot keep up with me once I have taken her past redline on my SOHC ZC and manually change the gears, keeping her in torque band...
