In the 200 Club
I removed the ECU so long ago I forget how it mounts back in there. Does somebody have a diagram or a picture or a thread that shows the mounting config? I checked my manual, and all over utube, and search engines.
1923 Model T 'Stake' Truck, see in Legends of the Fall 1949 Chevy 3/4 Ton, had 214 ci now 235ci 1959 Dodge Mayfair 1986 Ford Ranger 4 cyl 1993 Pontiac TransSport 3.8 1996 Chevy 3/4 Ton 4x4 1999 Oldsmobile Alero 2004 BMW 330i |
Re: R&R ECU 1993 Trans Sport 3.8L
Here are a couple diagrams from the manual. It is located behind the glove compartment. GM manual very skimpy on how to change it; Haynes says to remove the lower panel to access it but I seem to recall that also removing the glove box in its entirety helped give more access. It just clips in and is secured by a nut. Not sure if it would help to install the 3 gang connectors first before fitting into final position-you may have to play with it to see
| The Following User Says Thank You to Jeffrv For This Useful Post: |
tinkering (07-15-2022)
In the 200 Club
I have a manual but I can't seem to find anything in there. Your diagrams don't look familiar. I should post a couple pics of the configuration. I'll do that as soon as possible. Thanks a ton.
In the 200 Club
I am having trouble uploading some pictures of the PCM/ECM and the vacuum junction. I see where the vacuum junction block mounts with 2 screws but I'll be danged if I can remember how and where exactly the ECM attaches under there.
In the 200 Club
One pic per post because of size.
In the 200 Club
Is there some clips that go in those little slots on the side of the ECM?
#7 | |
In the 200 Club
I can't seem to upload anymore pictures.
This is frustrating that I can't remember how it came out of there.
#8 | |
In the 200 Club
Does it have something to do with this. Is there a bracket that fits in there?
#9 | |
The PCM mounts on the firewall on passengers side, behind the convivence centre shelf. It has been a while since I changed mine so the memory is a little foggy. I believe the bracket as shown in the first diagram is an 'L" shaped bracket that I think also has a small lip bent at the bottom to hold the PCM case in place. The hook as shown just beside the arrow in the diagram holds the case in place at the top.
The manuals all state to just remove the lower hush panel and install the PCM. I found it was too awkward for me to be outside the van and try to push the PCM case up against the hook and slip the case into the bracket- both the back and the gut rebelled. Instead I removed the glove box to give me access to the top of the PCM case,tilt the case slightly out at the top, and slip the bottom into the bracket. Using both hands push down on the case while using the thumbs to gently bend the hook up to slip the case into the upper part of the bracket. GM manual doesnt mention it but the Haynes manual says there is a nut on the left side of the case to fasten it down. It has been too long since I did this to recall whether or not there was in fact a nut |
#10 | ||
In the 200 Club
Thanks a ton though. I will keep you abreast.
#11 | |
I have had microfiche for 1990 to 1995 U body for a while, but only just managed to get a reader for it. Looked up the PCM mounting, and they are very different for 92-93 vs 94-95.
The bracket is a different design there seems to be a plate bolted at the bottom as well as bolts at the top. I don't have the microfiche converted to digital, so here is a photo of the assembly, hope you can make it out |
#12 | |
In the 200 Club
It is hard to make out that picture but it looks like I am missing a bracket. I have to go through the parts containers. Will get back.
Thanks!
#13 | |
Tinkering:
have sent you a PM Jeff |
