Go Back   Automotive Forums .com Car Chat > Oldsmobile > Bravada
Old 10-25-2020, 02:43 PM   #1
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
New AC Delco fuel pump failed
The fuel pressure dropped a little and would not hold fuel pressure after the pump shut off.
Had a new AC Delco pump installed and it pumped up pressure but wouldn't hold it 2 seconds.
After having a new Delphi installed, which holds pressure for over 30 minutes, I applied 80psi air pressure to the discharge side of the AC Delco pump then the check valve started holding pressure again.
Anyone been through this?
Chris Stewart is offline   Reply With Quote
Old 04-10-2022, 09:33 AM   #2
Chris Stewart
AF - Advisor
Re: New AC Delco fuel pump failed
Well to update, I bought and installed the complete module, which contained the new fuel screen with much success. Turns out the old fuel screen had a tear and trash "trashed" the AC pump. You and I know now.
