| Register | FAQ | Social Groups | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
2002 pontiac grand prix abs+trac light on
yes, i own 2002 pontiac grand prix gt, the abs+ trac light come intermittently and go off when turn ignition off. i cleaned abs connectors and still does it any help will be appreciated?
Re: 2002 pontiac grand prix abs+trac light on
Its likely a broken/corroded wire. They like to break right where it attached to the control arm.
...Which is why many places sold sections of the ABS sensor harnesses and usually kept them in stock. As you know, it's fairly common, and somtimes right inside the cable itself.
Yeah. When I had my Grand Prix I had to replace a section on the passenger side. Dorman makes it usually.
thanks for the help
yes, has anyone changed a wheel speed sensor harness for this 2002 pontiac grand prix? my question is where does the harness 2 wires hook up too? and is it a hard job to do?
The ABS and TCS Off indicators are always lit on my 99. A year or two ago I had a shop read the ABS codes which revealed that the ABS electronic module had failed. The part was $1000 and I was reluctant to spend that. So now I just try to keep some extra space in front of me.
Lloyd 18 Charger ScatPack 392 18 Lincoln Navigator L (Hers) 98 Grand Prix GTP Sedan (RIP) 99 Grand Prix GTP Coupe (to the moon) 05 Wrangler Unlimited (Junior's) 03 Explorer XLT (Sissy's) |
Extra distance is unnecessary since ABS does not decrease stopping distance. The whole point of ABS isn't to decrease stopping distance, its to "maintain control."
| The Following User Says Thank You to Blue Bowtie For This Useful Post: | ||
DrRadar (07-29-2020)
yes, i had another question about this grand prix, could a front hub because this to set the lights on? becuse there is no dtc code when i read it?
A bad hub could cause it, but you'd still have some sort of DTC.
Two things though, your reader has to be capable of reading ABS codes, and two, the ABS light has to be on for the code to be able to be read. When I had my ABS light on my reader couldn't read it. I went into Advance and grabbed their reader and it showed the right front.
thanks for the help, my abs&trac light is on all time. i have a reader that is supposed to be abs and it still doesn't show no codes on reader?
It would still be helpful to have the actual error codes.
thanks everyone for the help, the problem was the speed sensor harnesses
