Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 09-09-2018, 10:16 PM
AMahnken AMahnken is offline
Hazards come on when I signal
2001 Camry LE
When I signal, my hazards come on. Sometimes it happens for a few minutes and clears up (signals work normal). It doesn't seem to be temperature related. The signals have not worked in the afternoon and worked fine at night and vice versa.
It's getting to be less intermittent and more common (hazards when signaling)
I can turn the hazards on and off at the switch.
Pulled headlight bulbs and signal bulbs. Checked fuses that deal with lights, they're good.
Old 09-10-2018, 11:26 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Hazards come on when I signal
If you have a separate fuse for the Hazard signal, pull the fuse and see if that solves the problem. If it doesn't solve it, it would imply that there is an intermittent cross-connection in the harness somewhere (both power touch through worn insulation). If removing the hazard fuse solves the problem, then I think that means that the problem lies within the hazard circuit. Just guessing...
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 09-20-2018, 09:20 AM
It was the flasher relay.
The Following User Says Thank You to AMahnken For This Useful Post:
Stealthee (09-20-2018)
Old 09-20-2018, 05:54 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Thanks for returning to post the fix. I was actually going to post that as a place to look before I saw your post.
