2013 2.4 No Heat!!
I have a 2013 2.4 liter engine. I was wondering if someone could steer me in the right direction with this problem. I have 38000 miles and I have no heat whatsoever. There is absolutely no change in temperature from cold to hot, and on any position. I have plenty of antifreeze and it is clean. The hoses going to the heater core are hot and the temperature reading on the gauge is half way like it always is. Any ideas will be appreciated.
Re: 2013 2.4 No Heat!!
We have no heat on the passengers side. Beginning to hate this car
We have no heat on the passengers side but drivers side seems ok
Sounds to me like a both of you have either temp door actuators or temperature door problems. Not sure where the actuators are located on these cars, but you could remove the actuators and move the doors by hand to be sure they are ok. There may be codes stored in the bcm or hvac module to assist in diag. A basic code reader will probably not read these codes.
Looks like you can pull the glove box out to access the actuator, doesn't appear to be too tough. On a dual temp set up, there will be an actuator on both sides on the HVAC housing. |
#5 | ||
