Old 03-03-2016, 11:49 AM
20GMC00 20GMC00 is offline
2000 C2500 stuck in closed loop.
I have an old body style 2000 C2500 with a 5.7. It has been getting harder to start. It has a new Delphi fuel pump and new battery. I need to crank it 4-5 times before it will start sometimes. Sometimes it won't start at all. I found out that if I put a 10 amp battery charger on it for just a few seconds, it fires right up. Also I have my live data scanner plugged in and it is staying in closed loop all the time and both rear O2 sensors are staying at 99%. It runs fine but it's just getting harder to start. Has anyone ever had this happen or have any ideas? Thanks!
Old 03-03-2016, 12:09 PM
j cAT j cAT is offline
Re: 2000 C2500 stuck in closed loop.
if the scan tool reports the wrong cold start temp then that is the problem
Old 03-03-2016, 01:33 PM
When should it go out of closed loop?
Old 03-03-2016, 01:53 PM
Looks like my fuel pump is taking a dump already. 50psi with key on and 60-62psi the second I put the battery charger on it.
Old 03-03-2016, 02:13 PM
I just took the filter off and the stuff that came out the inlet of the filter looked coffee.
Old 03-03-2016, 03:54 PM
777stickman 777stickman is offline
The system is in "open loop" when first started cold. The system generally goes into "closed loop" when 1) the o2 sensors get warmed up, 2) the ECT sensor reaches a specific temp, 3) after a specific amount of time from first start.
During normal operation the VCM will stay in closed loop and fuel is controlled by the o2 sensors.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 03-03-2016, 06:18 PM
at about 160deg f plus.
Old 03-03-2016, 06:20 PM
some one may have put crap in the tank. you will need to drop tank and wash it out. show picture .........
Old 03-03-2016, 06:49 PM
I will do that. Thanks.
Old 03-08-2016, 05:43 PM
It starts right up with the fuel return pinched off. Is the regulator replaceable or is it part of the spider? It's got 268,000 miles. I'd say it's about due.
Old 03-08-2016, 07:00 PM
The regulator is replaceable on its own. It's under the upper manifold.
57 Chevy 210
Old 03-08-2016, 07:23 PM
probably returning too much fuel . driver side of the intake manifold.
Old 05-23-2016, 11:58 PM
Finally had time to drop the tank tonight and it is still spotless on the inside. I'm guessing the pump went to crap causing the filter to be full of the black stuff.
Old 05-24-2016, 02:27 AM
harleyguy harleyguy is offline
To me it sounds like your having a battery/electrical problem putting a charger should not boost your fuel psi.
As for your closed loop problem what are you showing for ect. As stated that is one thing that tells it when to run closed/open loop.
Check for 12.6v on your battery and also to your fuel pump
Old 05-24-2016, 09:47 AM
The voltage is good. I put the charger on 10 amp and it will start within 10 seconds after putting the charger on.
