Old 03-14-2016, 04:19 PM   #1
Tootall91
Thermostat housing won't seal anymore help!!
So I was replacing thermostat in 98 lumina 3.1 and usee the wrong bolt for the upper bolt on the housing and it broke where it mounts onto the block. Now the housing won't seal over thermostat and just pisses coolant everywhere... anyone have this problem? If so is there an easier and less expensive way of fixing or do I have to get a whole new motor? I can post pictures too if needed
Tootall91 is offline   Reply With Quote
Old 03-14-2016, 05:59 PM   #2
aleekat
Re: Thermostat housing won't seal anymore help!!
Did you remove the broken bolt?
Post back, that's what makes Forums Work.
aleekat is online now   Reply With Quote
Old 03-14-2016, 09:42 PM   #3
Tech II
Easiest way to work on this, is to remove the throttle body(just need a new gasket.....
As Kat asked, did you remove the broken bolt? You will have to remove the housing again, and if enough of that bolt is sticking out of the lower intake, should be able to grab it.....
What do you mean wrong bolt? Too long? Too short? Did you damage the lower intake threads? No need to overtorque a rubber seal.....
Old 03-15-2016, 12:18 AM   #4
Tootall91
I'll post pictures of it on here shortly but yeah I used one ofor the bolts from the throttle bodyon accident that was too long
Old 03-17-2016, 12:32 PM   #5
Tech II
Did you overtorque and take out the threads? Crack the Lower intake where the housing attaches?
Old 03-18-2016, 08:29 AM   #6
rhandwor
If your repairs don't work you can purchase used parts at a scrap yard. Their is no need to purchase a complete motor. Ask to remove them from a scrap motor that was returned. They sell them for scrap and will want your damaged parts.
rhandwor is offline   Reply With Quote
