Go Back   Automotive Forums .com Car Chat > GMC > Jimmy
Old 11-30-2004, 01:14 AM   #1
kegaul1
Question 1997 GMC Jimmy stuck in 4 high.
I own a 1997 GMC Jimmy. The 4 wheel drive unit is stuck in 4 high what can i do to fix this? I have checked other Threads and have seen an encoder motor listed. when I press the dash switch I hear the motor ingage as the light flashes then it switches back to 4 high.
Thanks for help!
kegaul1 is offline   Reply With Quote
Old 11-30-2004, 01:17 AM   #2
BlazerLT
AF -Advisor
BlazerLT's Avatar
Re: 1997 GMC Jimmy stuck in 4 high.
Remove the negative battery cable from the battery.
This will reset the 4x4 system and allow you to go back to 2wd.
Then replace the encoder motor on the transfer case and don't use 4x4 until you do.
BlazerLT is offline   Reply With Quote
Old 11-30-2004, 09:57 PM   #3
Bajass235
My 97 did the same thing.
It was determined to be the actuator switch located on the side of the transmission. This I'm told is a very common failure point on Jimmys.
Good luck
Bajass235 is offline   Reply With Quote
Old 12-03-2004, 10:06 PM   #4
GMCTech
You should find that the vacuum switch located on the driver's side top of the transfer case will be the cause of your concern.
Hope this helps.
GMCTech is offline   Reply With Quote
Old 03-24-2015, 10:51 PM   #5
RagingMoose
My stepfather is having this issue and they switch under the driverside was removed and he still had this issue with it off what could it be
RagingMoose is offline   Reply With Quote
