Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 08-25-2005, 08:36 PM
falcn63 falcn63 is offline
problem with climate control 2001 sable
This problem started out of the blue with no warning. The car is equipped with that "automatic climate control". It is now blowing out hot air, I'm guessing at top heater temperature, regardless of where it is set. I does not matter whether the a/c is on or off or where the temperature control is set. The temp. can be set anywhere between 60 deg. and 90 deg. and it does not make any difference. It doesn't matter whether it is just on vent, defrost, or max. a/c.--still hot air. I clamped off the heater hose coming off the engine block, and that makes it cool right down and a/c is cold. So whatever is supposed to be shutting off the hot water to the heater core is not working. My problem is I don't know where to start. I checked to make sure no fuses were blown, but they are all ok. Does anyone know what the components of this system are? Are there sensors or sending units to check? And if so where. I assume there has to be some type of valve on the hot water circuit. Anyone know how I would check it? If anyone can point me in right direction I would appreciate it. Thanks.
Old 08-26-2005, 04:25 PM
DynoDon DynoDon is offline
Re: problem with climate control 2001 sable
There's no valve, just what's called a blend door. I've got the same problem, and will soon be digging into it further.
Pick up an owner's manual from the library for free and take a look at the appropriate section.
From what I've been able to find out you're (we) going to have to take the dash out to fix it...
Old 02-16-2008, 11:46 AM
x000402 x000402 is offline
I'm experiencing the same problem. Have you had the problem fixed yet?
Old 02-16-2008, 12:56 PM
No I haven't.. Sometimes it starts working on its' own and I kind of forget about it. Wish I could just access the blend door with something to knock it loose... Sooner or later I guess I'll have to get it fixed I guess
Old 03-23-2008, 03:03 AM
rladue01 rladue01 is offline
I am having the same issue. Has anyone found the answer??
Old 04-03-2008, 11:50 AM
98SableGS 98SableGS is offline
My 98 Sable GS 3.0 V-6 had no heat as well. The engine would come up to temp and the coolant was full and was not leaking. With the engine warm I felt both hoses on the heater core. The hose going in and the hose coming out were both hot, the same temp. I then discovered that the blend switch was only working in the cold position (blue color). This was true for the air cond. and heat. The blend switch door is located next to the floor in the middle. I used a screw driver and some spray to free it and it has worked fine ever since. There was no need on this car to take anything apart. Good luck.
Old 03-27-2013, 10:08 PM
kwirob kwirob is offline
hi had this we took out the glove box unpluged a wire bunch and plug back in and it fixed the part cost bout 257.00 from the dealer hopeing not haveing to replace the part it has been bout a month the guy that fixed it said could last or not control box was reset any 1 any more info email [email protected] you donot have to take out the dash i was quoted 600.00 to pull the dash i ran fast ill tell u
Old 07-18-2014, 08:14 PM
mugydoo mugydoo is offline
This video on Youtube shows how to change the vent door actuator Which is a common problem with the climate control. (96-07 mercury sable) Hope this helps.
http://www.youtube.com/watch?v=xK7rP49gfio
