Go Back   Automotive Forums .com Car Chat > Buick > Buick Classics
Buick Classics Discuss older classics here.
Old 10-18-2014, 01:30 PM   #1
John1397
How much wear is to much
I have a crank from a car and the rod bearing has turned and is about 2" diameter it has wore .010 away is this to much and if not what is the maximum diameter in thousandth of an inch that can wear off so that the crank can not be reground?
I do have another crank that is in better shape but it has a slight grove wore in wear the rear seal rides and my crank uses the rope type seal with all those diagonal lines stamped in. I would like to use a rope seal but if the crank surface is smooth without those small lines stamped in would this still work?
John
John1397 is offline   Reply With Quote
Old 10-18-2014, 03:46 PM   #2
DeltaP
Re: How much wear is to much
The only person who can answer that is the machinist after he checks the crank. Hopefully you can offer up more info as to what you're working on. But in my opinion 0.010" sound excessive for most crankshafts.
DeltaP is offline   Reply With Quote
Old 10-18-2014, 08:13 PM   #3
maxwedge
A990 racer
Most cranks can be undersized to .030, if bearings are available of course. Not seeing this groove your machinist can tell moe than we can.
Old 10-19-2014, 09:32 AM   #4
DeltaP
Duh... my mistake. Not only did I read it wrong, I quoted it wrong. I missed the '.0'
