| Register | FAQ | Social Groups | |||||||||||||||||||||||||||||||||||||||||||||||
99 K15005.7L-Replaced timing chain and now won't run
Thank you in advance for your help. I just replaced the timing chain and water pump on my 1999 K1500 5.7L. After spending several evenings and a few early mornings working on it, I get everything back together and go to start it up. It starts then immediately dies. After double checking that the CKP sensor, two plugs on breather, and a/c and altenator wires (these are all that I unplugged) are connected I try in one more time before coming in to work today.
Timing chain was installed with No. 1 at TDC and mark on cam at 12 o'clock position as stated in the Haynes manual for the truck. I did not remove or even touch the distributor since replacing the intake gaskets ~3 years ago. Will check to see if any codes are showing in the morning when I have my laptop at home. Any ideas as to what I should be looking for are greatly appreciated. -Ben |
Re: 99 K15005.7L-Replaced timing chain and now won't run
Isn't that a symptom of anti-theft (PassKey system, or similar) activation?
Did you manually turn the crankshaft a couple of revolutions and then verify that the timing marks still align? Is this a multi-keyway crank sprocket, and if so are you sure you used the correct keyway? Will it stay running if you hold the key in the "crank" position (hard on the starter, but would help diagnosis)
. . For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China. |
| The Following User Says Thank You to Schurkey For This Useful Post: | ||
Termite1988 (09-25-2013)
I did however try to start it again this morning and it fired off and ran normally with no SES light. There had been nothing done to it since yesterday's failed attempts at starting it. My better half claims it was her touching it but I have my doubts. Only let it idle since it was early and still had family members in bed that I shouldn't wake. I am off tomorrow and will take it for a few short drives and let you know what it does. Thanks, Ben |
with the power off for a long period this can occur . since it seems to work now it is possible the lock cylinder security pick up is going out.. |
-Ben |
