Old 03-11-2012, 06:28 AM   #1
sukkhi.fuel
Camless Engine
Most of us are aware of the advantages served by the Variable Valve Timings, and we have been using them since quite a time. But this is still a compromise as these employ 2 different profiles, one for the low speeds and other for the high speed.
While using the Camless technology,
We can achieve infinitely variable valve timing across the whole RPM range where lift and valve timing can be adjusted freely from valve to valve and from cycle to cycle.
Link to the one such project with electrically actuated valves.
http://www.youtube.com/watch?v=sRBhqy4LpnQ
sukkhi.fuel is offline   Reply With Quote
Old 04-04-2012, 05:23 PM   #2
Tesla220
Tesla220's Avatar
Re: Camless Engine
BMW has been working on this for some time.
Chance favors the prepared mind
Tesla220 is offline   Reply With Quote
Old 04-07-2012, 12:10 AM   #3
vgames33
Re: Camless Engine
The technology has been around for a while. If I recall, its not to a cost vs power/mpg payoff yet.
vgames33 is offline   Reply With Quote
Old 04-08-2012, 08:24 AM   #4
jdmccright
The RustBuster
jdmccright's Avatar
Re: Camless Engine
The system is quite heavy, too. You've got the magnets, spring dampers, and coils above each valve, which have to be fairly stout to generate the forces needed to open and close them without also destroying them. And all that weight is above the car's CG, affecting handling.
It sounded great when it first came out, but as in all new breakthroughs, the devil is in the details.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
jdmccright is offline   Reply With Quote
Old 04-08-2012, 03:55 PM   #5
vgames33
Re: Camless Engine
I suppose that makes sense. A solenoid capable of popping valves open at 7000 RPM would likely beat the valve and valve seat to bits in short order. Like a cam with a fast ramp rate.
Old 04-18-2012, 03:46 AM   #6
ChevyImpala67
ChevyImpala67's Avatar
Re: Camless Engine
That's pretty interesting at the same time not practical so more than likely it will never become into production if so many decades from now.
ChevyImpala67 is offline   Reply With Quote
86 buick lesabre estate wagon with 70's olds 455 big block engine in need of help kcbuechler LeSabre 29 06-26-2012 10:21 AM
97 lumina engine acting erratically. aptivaa12 Lumina 5 04-22-2009 10:42 PM
Engine Swap 1996 4.3 S10 Engine Going In A 1991 Blazer What Changes In Exchange in2classx Problem Diagnosis 1 08-27-2008 10:05 AM
Cold engine = stalls Hot engine = rough idle Dave01234 '97 - '03 2 02-20-2008 12:35 AM
Tags
camless , camshaft , project , valve , vtec
