| Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
'90 LX 5.0L 5-Sp Unintentional Revving
While driving into work this morning, my car started revving up to about 2,000 RPM when I stepped on the clutch. Every time I shifted gears, the engine wouldrev up to about 2,000. I seem to remember someone suggesting that the Idle Air Control valve might need to be cleaned. Any ideas?
Thanks.
-1990 Mustang LX 5.0L 5-Speed All Stock! except the stereo...-2005 Yamaha V-Star 1100 Custom ![]() -2008 Toyota 4Runner Ltd 4.7L AWD ![]() -2019 Subaru Ascent (the wife's)
Re: '90 LX 5.0L 5-Sp Unintentional Revving
Check for a vacuum leak first. Listen for a hissing noise along the vacuum lines. You can get a vacuum gauge also to check for proper vacuum pressure.
If no vacuum issues are found, than clean or replace the IAC valve. They've been known to go bad.
![]() 2000 Mercury Grand Marquis LS - 119k / 14.89s @ 92.11MPH [ pictures | videos ] > Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok > Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB > BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms > CVPI aluminum driveshaft |
#3 | ||
Stanger
Technical Service Bulletin; 91E19 MAR 92 Recall - Wiring Harness Modification
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 |
#4 | ||
Re: '90 LX 5.0L 5-Sp Unintentional Revving - Part Two
I have not heard any noise that might indicate a leaking vacuum hose. Where all do I need to listen for one? What else can I check? Thanks.
