Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 03-17-2012, 12:30 AM   #1
Harlem1Der
1998 Bravada Gauge Cluster
I bought my son his first vehicle, a 98 Bravada. We've had it less than a week and so far the major problem we have come across is the lights in for the gauge cluster in the dash are not coming on. First I thought it was a blown bulb so we replaced that. When we were putting the dash back together, I turned the truck on and turned on the headlights and got nothing. So I jiggled some wires thinking that it might've been a short or a loose wire and still nothing. It was getting dark so my son decided to put everything back together and try again in the morning. When he reconnected the connector for the dome/fog light, everything came back on. But when he moved the dashboard to put it back in place, everything went back out again. Again, I jiggled wires and nothing, not even a flicker. Now there's no lights in the dash and when he turns on the headlights, the radio lights go out along with the compass/MPG gauge located overhead. Any ideas as to what the problem might be?
Harlem1Der is offline   Reply With Quote
Old 03-23-2012, 10:08 PM   #2
Rick Norwood
Big Tall Dumb Ass
Rick Norwood's Avatar
Re: 1998 Bravada Gauge Cluster
First thing is to make sure all of your fuses are good (not Blown), tight in their sockets, and are physically all there (not missing). This is a common symptom of a bad ignition switch, but the ignition switch is not always the culprit. 97's and 98's are flat notorious for having bad ignition switches. The ignition switch is mounted to the Steering column. Try specifically wiggling the Pink wire at the ignition switch. There are many threads on this forum pertaining to the ignition switch. Do a search. Also make sure none of the bulbs are blown and possibly shorted.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Rick Norwood is offline   Reply With Quote
1998 Bravada Short Between Fuel Pump and Tailgate Glass Release PirateFish4x4 Bravada 5 01-05-2011 10:58 PM
92 cavalier instrument cluster burning out? do it myself often Cavalier Problem Diagnosis 0 01-01-2011 11:23 AM
01' gauge cluster with trans temp gauge? attackdog Yukon 0 11-01-2005 10:49 PM
92 gauge cluster to 94-96 cluster CocaColaEatsPie Prelude 0 03-07-2005 07:36 PM
F/S celica st185 gt4 gauge cluster and indiglow gauges speedlabracer Classifieds 0 08-10-2004 04:14 PM
