Need advise on Isolator/Intake repair..
I have an 01 Windstar, 3.8L with the classic 171/174 continous CEL code. Though it has 152,000 miles, it runs smooth. It has started the "baffle knock" in the last few months. I have attempted the MAF clean and can find no air leaks on any line or on the exterior of the intake itself. My main two problems are the knock and the continuous CEL slapping me in the eye every time I drive the van. I plan to complete the TSB repair but with some reservation. I want to ask a few questions before starting the isolator/intake repair.
1. What does the baffle knock consist of? Is it due to being loose or is it normally a broken baffle? What is hitting against each other to cause the knock? 2. I have read many cases to where the new isolator bolt broke during installation although they did not even use the full 89# of torque? Advise? 3. Many attempt to fasten(RTV) the baffle to the intake? Is this necessary and does it prevent the knock? 4. Can I just plug the hole in the valve cover to prevent future problems or must I replace it? 5. Should I bother with the lower intake area since it runs good and not losing any fluids? 6. Can someone provide the parts list for the 01? Appreciate the help, JoeJWill |
![]() Join Date: Sep 2004
Re: Need advise on Isolator/Intake repair..
I have a '96....which uses a different intake manifold........ So I do not know much about the '01.
I have saved this link.....which a member put up with some great information....and pictures that should be a great help to you.... http://leckemby.net/windstar/windstar01.html |
Wiswind, that is a good link.
BTW, my Haynes was written for the '95 thru '01 models. The specified torque for the isolator bolts, for '99's, is written therein as 89 in-lbs, ... not 89 ft-lbs. |
A quick note:
I just performed the isolator bolt/revised valve cover TSB this weekend on my 2000 Windstar LX 3.8, using the leckemby.net procedure reference above (many, many thanks to the author). Overall perceptions: - At first, I was intimidated by the procedure. But once starting work, it really wasn't terribly difficult. I was done in about 3.5 hours (admittedly, I did it late at night and was pushing along to make sure the van was driveable the next morning) - I didn't bother with a torque wrench on any of the bolts. Yes, I've seen confusion between in-lbs and ft-lbs on listed figures. Note that the isolator bolts don't actually tighten directly onto the plastic manifold; they have a steel sleeve the transmits the torque to the lower manifold (which is cast metal). The plastic/rubber seal really does the bulk of the work. Note that 89 in-lbs only translates into a 7.5 pound force on the end of a 1 foot long wrench; none of the bolts in this entire project really get very much force. - The baffle is made of the same black plastic material as the upper manifold. It has tabs that are designed to snap into the upper half of the upper manifold. Yours may be loose - but it really can't move very much. I'd be worried that RTV inside of the manifold might get loose and get sucked into a cylinder. - I compared the two valve covers; it's likely that plugging the hole would accomplish that same goal as the new valve cover - but I had already paid for it, so I used it. I probably should have removed the metal plate (that's visible through on the PCV mounting hold) on both manifolds, to check if other changes were made underneath the plate, but didn't want to take the time. - I didn't bother removing the cowl. By removing the IAC, I was able to get enough room to jockey the upper intake manifold off of the engine. I also had no problem reaching fasteners on the back side of the manifold, but concede I have thin hands and arms. - My van (at 70K miles) didn't yet have the 171/174 CEL, but problems with occasional knock have gotten much worse recently, so I opted to perform the TSB now. So far (only one day's driving), the van runs much better; knock is gone. I'd encourage you to tackle the TSB. I have decent DIY automotive background, but with the aid of the procedure, the repair was very straightforward. I hope this helps. |
![]() Join Date: Feb 2004
Joejwil,
I agree with Phil-1 in that it is straighforward and an experienced DYI should have no real problem but you do need to judge your own abilities. Things I would do differently: -I would use a torque wrench. (Esp. since the plenum is plastic) -I would remove the cowl. -I would change the plugs if due while you have the cowling off. Seems like you read most of the 171/174 threads. I was the one (iirc) that started asking about pluging the hole in the baffle. For the record I never tried it and I don't recall anyone ever giving feedback that they had tried either. I still think I would do it if I ever had take the valve cover off for some other reason. Not too sure what you were refering to in regards to the "lower intake". The parts list is in the TSB. I think there are links buried in the forum. If not I know I have them somewhere. |
#6 | ||
Re: Re: Need advise on Isolator/Intake repair..
The leckemby.net procedure includes a more complete parts list than the TSB (which specifically calls to *not* replace the gasket between the uppper manifold halves; I'd replace it). Hmmm - one of the reasons I didn't use a torque wrench is that I didn't have one that goes that low. I should probably get a nice small "lower range" torque wrench, just for such projects. I had recently changed the spark plugs on my Windstar - the rear 3 requiring the painful lay-on-your-back-and-reach-up-there method - so I skipped that portion. I suspect it would have been easier to remove at least the top half of the upper manifold, simply for spark plug access. |
#7 | |
![]() Join Date: Aug 2004
I had the lovely opportunity to due this TSB twice since Ford gave me the same easy to deteriorate isolator bolts. The second time around, the new isolator bolts seemed to have a different rubber sleeve (green). You will need these because I also replaced the valve cover (and I did take them both apart) to realize that the only difference was the hole. The oil blow-by problem will not go away with or without the new valve cover, trust me on this one. I currently have attempted the in-line filter home made modification and I have yet to come to a conclusion if it helps or not. I also had the baffle knock and after several pros and cons from posters here, I decided to RTV with a good brand and have had no problems. As a matter of fact, its down right hard to get the stuff off after a removal for inspection purposes. Good luck and all the info needed for the mod I have found here.
#8 | ||
Yup, I made sure my new isolator bolts had the green bushing... |
#9 | |
![]() Join Date: Oct 2003
Here's the filter setup in a 3.8L Mustang, a little different layout but same idea:
http://www.miracerros.com/mustang/pcv_filter.htm
1997 Pathfinder XE Air Lift Air Bags, Warn Hubs 2000 Windstar SEL |
#10 | |
Re: Re: Re: Need advise on Isolator/Intake repair..
Thanks for the link.
Note for others: The previous link also includes a detailed view of changes made to a valve cover. While it isn't technicall a Windstar valve cover, the changes appear to be identical to what I saw on my Windstar. This means budget-sensitive Windstar owners should be able to modify their original valve cover to match the revised cover. You'd probably only need to some tin snips (there is one corner of the interior baffle that has a new notch), a pair of pliers (one corner is bent slightly differently) and some reliable way to plug the hole (I'd suggest an appropriate size bolt, with a nylock-style locking nut). The filter looks like it does the trick. My '95 Ford Contour is also noted for oil from the PCV line causing intake crud problems; I'll look into these solutions. |
#11 | |
I also had to do the upper intake manifold the second time to get the improved isolator bolts ... similar to Mackab's experience. I also did the RTV "fix" the first and second times ... with good results. I did the second repair before conditions were bad enough to cause codes.
I don't remember exactly, but I'm sure the first repair had 50 kmiles or more before the second one. And even though the upper intake manifold was oilier the second time around, there was NO PLUGGING of the EGR jets. FURTHER, THERE WAS NO SLUDGING DOWN INSIDE THE LOWER MANIFOLD CYLINDER INLET PORTS. The IMRC butterflys were as clean as I left them in the first repair. I attribute this all to the fact that the upper plastic assembly was completely RTV-sealed to the plastic "spacer". That is, each of the six air horns was sealed at its lower end .... where each is inserted down into the spacer. (Those who have been "in there" will know where this is). This action forced the oil to pool on top of the spacer and only go lower into the intake "inside an air stream" .... not seep down around the outside of the horns ... where it clings to walls and does not get into the combustion chamber borne on air. So, in my situation, the oil collects on top of the upper intake spacer until the pool gets so high that some of it may be picked up by the intake air and carried over inside one or more of the horns. I contend this does no damage and will not cause intake gumming. Now what I did, with the RTV, was a bit extreme. You have to believe that the RTV bead that you put in place will stay in place and not go below and take up residence under a valve head ... or worse. So I'm not suggesting you do as much sealing as I did .... a little RTV is all that's necessary to get rid of inner baffle noise and vibration. However, I would caution everyone on any efforts to eliminate the oil getting into the upper intake chamber "in the first place". The PCV path has been well engineered, I think, and does a good job of keeping the lower short block free of combustion sludge ... at the small cost of returning some crankcase oil up to the top of the intake. DON'T tamper with the PCV path unless you are willing to pay the price of a misadventure!! |
#12 | |
Can you share some more about how you sealed the bottom of the baffle air horns to the lower half of the upper intake manifold?
As I recall, there's a slight 'lip' near the top of each air horn on the lower half of the upper intake manifold. I'm guessing you ran a small bead of RTV around each, and then seated the baffle into the RTV. Did this make it more difficult to place the upper intake manifold (i.e., normally the baffle is 'clipped' into place, then installed with the upper half of the plastic manifold) or did you place them both together (meaning you can't actually see how well the baffle seated into the RTV)? This is an interesting approach. |
#13 | |
Phil-l
I think you imagine it pretty accurately. I first secured the inner baffle to the upper piece using a few scattered daubs of RTV. (My retaining clips had already broken off before the first repair ... they were waiting for me atop the spacer). The two parts were pressed together and the RTV allowed to cure a bit. On installing the upper (two-part-assembly) to the plastic spacer: I first did a sealing experiment on a single horn ... allowed some cure time ... and then pulled the upper away from the spacer to evaluate the seal. (You're right. You can't see what the results are without disassembly). The final method was to run a RTV bead in each female "nest" and also a mating bead around each male horn tip. You have to work pretty fast to get all this done before curing begins ... especially on a warm day. The bead diameter was approx 1/8" - 3/16". Using my finger, I trimmed the beads to what I felt was a shape that would surely seal the joints. |
#14 | |
Thanks for the info.
I must admit, I'd be scared that some of that RTV would blob up enough to become a piece that ultimately falls off (I once had something similar happen in an auto cooling system; the piece of silicone ended up getting stuck in the thermostat, holding it open). But it is surely an effective method of keeping any PCV oil out of the intakes. And a small - very small - piece of silicone would probably ultimately make it out the exhaust without damaging anything. If you ever pull it off again, let us know if it looks like the silicone 'rings' look to have survived without losing any material. |
#15 | |
Yes, will do.
And remember, this is the second time I've done this procedure ... I could not see any loss of RTV material. The "RTV rings" were all in place, most clung to the female spacer upon the disassembly, ... a couple stayed on the horns. |
