Old 10-30-2011, 09:16 PM   #1
ieavei
need help identifying part
Anybody know what this is and where it comes from?
ieavei is offline   Reply With Quote
Old 10-30-2011, 10:08 PM   #2
shorod
SHO No Mo
shorod's Avatar
Re: need help identifying part
It looks like an oil pressure switch. Often they are located either low on the block or near the oil filter.
Do you know if this is from a particular make and model of car? That information would certainly help narrow it down.
-Rod
Old 10-30-2011, 10:20 PM   #3
ieavei
I found this on the floor beside my car today. Is it possible it could have just "fell off" on its own? Make and model of my car is: 2008 Honda Civic LX Sedan, 5 Auto.
Old 10-31-2011, 07:52 AM   #4
shorod
SHO No Mo
shorod's Avatar
I don't really think it would have fallen off on its own. Considering the corrosion over much of the part, and how clean the threads and mating surface is, it either hasn't been loose long or it wasn't exposed to corrosive materials since being loose.
Did you find it on the floor while your Civic was parked in your garage? If so I'd be inclined to think it was in a box or cabinet in the garage and fell out after getting bumped or the cabinet door being opened. One of those, "I'm not sure this is bad so I'm going to save it in case I'm in a pinch some day" items.
-Rod
Old 10-31-2011, 10:15 AM   #5
jdmccright
The RustBuster
jdmccright's Avatar
Unlikely it came off by itself:
1) It would have to both unscrew itself AND come disconnected from the wiring, which in itself would have to be twisted in order to allow it to unscrew.
2) It is way too clean if it is an oil switch. It is dry.
3) If it was an oil switch, it wouldn't be laying on a dry floor...there would be at least a puddle of oil around it. And you'd have no oil in the engine, or none after driving a short distance AND seeing a check engine light for a bad sender circuit.
4) If it did fall, it would be under your car, not next to it.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
jdmccright is offline   Reply With Quote
Old 10-31-2011, 12:46 PM   #6
vgames33
Looks Japanese. Possibly from a Toyota?
vgames33 is offline   Reply With Quote
Old 11-01-2011, 07:58 AM   #7
shorod
SHO No Mo
shorod's Avatar
Looking in the sensor end of the third picture there appears to be something either oily or carbon- /petroleum- based that this switch was used with.
Most of your other points are why I suspect it fell from a box or cabinet in the garage where I'll assume the car was parked (and was probably cleaned up a bit before going in to storage).
-Rod
need help identifying part gw84 General Discussion 2 09-28-2007 06:12 PM
'84 Trans Am G - Speedometer Problem, Need Help Identifying Part Fit4Demolition F-Body Problem Diagnosis 3 04-25-2007 12:31 PM
Need Help identifying part robarrix Metro 4 08-03-2005 02:20 PM
i need help identifying parts SSpeeDEMONSS Grand National/GNX 4 03-09-2005 11:04 PM
Need Help Identify Part sickhonda Accord/TSX/Accord Hybrid 5 07-16-2003 02:29 PM
