Go Back   Automotive Forums .com Car Chat > Pontiac > Grand AM
Old 10-15-2011, 12:17 AM   #1
LordX2
2002 Grand AM GT (2 door) - Driver Window goes down - but not up (well)!!!
I have a 2002 Grand AM GT 2-door.
The driver side window goes down all the way.
On the way up though, it stops at 1/2 - then I have to 'help' it up. Then it stops at 3/4 of the way up, more help - then finally closed. (If I want it all the way closed, I still have to push UP on the window to get it to seal).
The motor is obviously working - what is causing this problem?
LordX2 is offline   Reply With Quote
Old 10-15-2011, 10:06 AM   #2
gmtech1
gmtech1's Avatar
Re: 2002 Grand AM GT (2 door) - Driver Window goes down - but not up (well)!!!
The motor can't handle the load to push the window up. I had one just this week, I pulled the motor and ran it, it worked both directions. Reinstalled it and no go. Replace the motor. If you can get the motor and regulator as an assy, do that. These are bad for regulators failing also.
gmtech1 is offline   Reply With Quote
Old 10-15-2011, 12:07 PM   #3
LordX2
It seems to get stuck at the EXACT same place though each time.
Almost like the windows isn't aligned properly or something.
Is that possible? Someone said locally to me that there are 'clips' or something of the like that can break and cause the window to come out of alignment...
Old 10-15-2011, 12:18 PM   #4
gmtech1
gmtech1's Avatar
Your window does not have the guide clips that secure the window in the run channels. What you are describing is common. Replace the regulator assembly with motor and be done with it.
Old 10-15-2011, 01:29 PM   #5
Tech II
Agree with GMtech1....if the window DOESN'T cock at an angle going up or down, the motor is bad(internal circuit breakers are tripping)....
Old 10-15-2011, 01:53 PM   #6
LordX2
It does seem to be cocked a little bit.
Even when I get it 'all the way up' it is still open a bit in the rear of the window, and I have to use my hand to push up the window to get the rear to close.
So it isn't going up totally straight.
Old 10-15-2011, 08:37 PM   #7
Tech II
It's still the motor.....when you pull the door apart check the clips that hold the glass to the regulator....
Old 10-15-2011, 11:10 PM   #8
LordX2
This is probably one of the issues on this car that I will have my mechanic work on.
I have heard horror stories of working on window motors.
Unless anyone knows of a pictorial (or youtube video) of motor replacement, I don't know if this is something that I can tackle.
Old 10-16-2011, 04:29 PM   #9
LordX2
Any recommendations on where to get a replacement motor for this?
Is Gmpartsdirect still the place to go?
Or is there a reputable place that has aftermarket or repaired motors?
Old 10-16-2011, 08:03 PM   #10
Tech II
Try RockAuto?
2000 Taurus drivers window goes down but not up mac-gt Taurus | Taurus Wagon 3 10-03-2009 10:46 AM
Driver door window goes down but not up wagle100 Sienna 1 02-06-2006 03:07 PM
1987 k5 Blazer rear window goes down but not up without pushing on door? sterm Blazer 1 07-25-2005 12:12 AM
Window goes down but not up!!! tapnap TrailBlazer | Trailblazer EXT 1 01-15-2005 11:02 PM
driver side window goes down but not back up! j30s_are_nice Cedric | M45 | J30 | Gloria 6 12-17-2004 10:17 AM
