Old 03-02-2011, 11:34 AM   #1
skelliej
my 93 accord doesnt start all the time
if i let it sit for about 10 mins it will start does anyone know what is wronge with this
skelliej is offline   Reply With Quote
Old 03-02-2011, 03:08 PM   #2
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
Re: my 93 accord doesnt start all the time
Not much meat on this bone.
Year/model/engine/mileage
Turns over with no start, doesn't turn over at all....does it when engine is warmed up, cold, what?
...empty gun rack.
Old 03-02-2011, 03:22 PM   #3
skelliej
its a 93 accord lx 2.2 it turns over and starts for 1 second then stalls then it wont start for about ten min but it still turns over and most of the times it starts right up it does it hot or cold
Old 03-02-2011, 09:03 PM   #4
jeffcoslacker
Ever have any problems with accessories like radio or gauges not working right when it's running?
In the meantime, try wiggling the key forward and back just slightly while it's running...not enough to hit the start or acc positions, but just rock it gently within the run position...tell me if it breaks up or dies, or if anything else in the car quits working while you do this.
...empty gun rack.
Old 03-02-2011, 10:10 PM   #5
CivicSpoon
There is no Spoon
CivicSpoon's Avatar
Check your spark plugs. My '94 Civic did something similar for a while, until I saw that my plugs were toast. Replaced them, and it worked fine after that. If you do get the car to start, you could check the spark plug wires. Let the car idle, get a spray bottle with water in it, and lightly mist the wires. If you hear an idle change, replace them.
CivicSpoon is offline   Reply With Quote
Old 03-03-2011, 01:54 PM   #6
somick
somick's Avatar
Search this forum for Main Relay.
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
somick is offline   Reply With Quote
Old 03-03-2011, 06:54 PM   #7
jeffcoslacker
Sam
That's where I was going next if the ignition switch seems ok...
...empty gun rack.
Old 03-03-2011, 07:09 PM   #8
snshddog
I have found that same problem with spark plugs. Hondas dont seem to want to run on anything but ngk plugs, and they go from good to bad overnight, runs great for years then suddenly bad plugs.
snshddog is offline   Reply With Quote
help Speedometer doesnt work all the time bomb shell C-Class 0 06-13-2007 07:03 PM
1997 pontiac gt heads up display doesnt work all the time swang29 Grand Prix 1 02-10-2006 02:09 AM
95' Trooper won't start all the time yofatmama Trooper | SLX | Bighorn | Wizard 5 02-20-2004 09:02 PM
my car doesn't wanna start all the time rps180jpowner 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 3 05-18-2003 11:58 PM
2000 Z3 door handle doesnt work all the time fusionpunch Z3 3 03-28-2003 06:51 AM
