Go Back   Automotive Forums .com Car Chat > Honda > Del Sol
Old 06-09-2010, 03:20 AM   #1
fullof?sformy93
Need help
a friend of mine is offering me a D16z^ that needs the head put on and i was wondering if it would be improving much from my d15b7
fullof?sformy93 is offline   Reply With Quote
Old 02-05-2011, 01:32 PM   #2
amy@af
Traffic Directing Admin
amy@af's Avatar
Send a message via Skype™ to amy@af
Re: Need help
it depends...z1 or z6? It depends on what your after. It's basically a mini-me swap. You'll need to swap dizzy & ecu. I've learned through the years different strokes for different folks. Some people turning a wrench is easy, it's not big deal. Others don't turn a wrench & it's easier to actually upgrade to a different motor
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
amy@af is offline   Reply With Quote
Old 02-06-2011, 11:51 AM   #3
FrodoGT
FrodoGT's Avatar
Re: Need help
If your b7 is still in proper running order and you are not looking to perform a full engine swap, I would suggest throwing the z6 (assuming it is one) head onto the d15 short block. It requires minor work, far less labor and with the higher compression will net you roughly the same hp figures that the stock d16 would. Its been done thousands of times, and you can find writeups all over the place. Also, you would still have the spare short block if you ever did happen to destroy one, or wear it out.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
FrodoGT is offline   Reply With Quote
