Go Back   Automotive Forums .com Car Chat > Chevrolet > Impala | Impala SS
Old 05-22-2011, 09:17 PM   #1
yrles1
07 Impala - How to change Evap Solenoid?
How do you change the Evap Vent Solenoid on a 2007 Impala LT Flex fuel. Dealer diagnosed Large EVAP emission leak and estimates $250 to charge. I ran the diagnostics and got a P0455 code.
I can get the part for $25, but not sure how to replace. Do you have to drop down the EVAP Canister to get at the Solenoid?
if so how does the Canister unmount?
Trying to save my 81 year old Mother in Law a $250 repair if possible.
Thanks much!!
yrles1 is offline   Reply With Quote
Old 05-24-2011, 12:27 AM   #2
oldblu65
oldblu65's Avatar
Re: 07 Impala - How to change Evap Solenoid?
Did anyone test your gas cap to be sure it was properly tightened or if it was defective ? A bad or loose cap will trigger a P0455 code . You didn't mention the cap so I don't know if that's a possible cause ? Go to the following website for a better description of possible causes and hints for resolution of the code . Go to http://www.obd-codes.com/P0455 .
" Sometimes I grow so tired "
oldblu65 is offline   Reply With Quote
Old 05-25-2011, 06:27 PM   #3
yrles1
Thanks for the extra advice and the OBD web site. I just read it and added it to my bookmarks. It's my Mother-IN-Laws car and she had just taken it in that day for another issue and the check engine light appeared on the way there. Dealer diagnosed problem as evap solenoid for $115 plus $250 to repair. Ironic that she stopped for gas on the way there. First thing I'll do is replace gas cap..Seal looks worn!! I will then clear the code and let her drive for a while and see if it returns. I won't attempt to install the solenoid yet, the part just came in at Advance Auto. Thanks!!
EVAP solenoid on 2006 impala phil43055 Impala | Impala SS 14 04-28-2009 12:08 PM
94 Regal 3.8 Engine - How To Change TCC Solenoid DJM1450 Regal 2 12-19-2007 10:10 PM
Battery Light, Trouble Codes PO443 and PO449: EVAP Solenoid Valve cflanigan Malibu 6 11-13-2006 05:07 PM
Too hard for vw techs, nobody knows how to change shiftlock solenoid juanche77 '97 - '03 4 01-24-2006 09:23 PM
how to change gearshift solenoid on automatic 98 jetta?? juanche77 '97 - '03 0 01-21-2006 06:29 PM
