Go Back   Automotive Forums .com Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-30-2010, 06:50 PM   #1
yamaharacen232
1989 cutlass ciera running rough
i picked up a 89 cutlass its got 83k on it so i figure perfect for the winter. its got the 3.3 liter v6 in it. my problem is when i drive the car for 5 min plus at 50 plus mph it tends to shutter a little bit when i let off the gas and the idle wants to stay at about 1000 rpm as aposed to the 800 before it hit the 50mph for a while. im just wonderin if it could be some sort of sensor that fouled or what else i should look into. the car doesnt stall out just idles higher and has that shudder. any thoughts? thank you for your time
yamaharacen232 is offline   Reply With Quote
Old 10-31-2010, 09:11 AM   #2
maxwedge
A990 racer
Re: 1989 cutlass ciera running rough
Shutter is rough idle /misfire? If so look for a vacuum leaks.
93 ciera runs rough zeakieb1 Cutlass Series 2 10-26-2011 01:21 AM
1990 cutlass ciera running bad shadowed05 Cutlass Series 4 02-26-2010 12:14 PM
96 Cutlass Supreme w/ Rough Idle, but drives good chrisluna Cutlass Series 1 09-17-2009 08:29 AM
94 Ciera running rough ollie31 Cutlass Series 5 12-28-2006 08:45 AM
99 cutlass is running rough in idle and while driving Beercommie Cutlass Series 2 03-09-2006 08:52 AM
