Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix
Old 10-25-2010, 11:43 PM   #1
proscroby
proscroby's Avatar
Question Headlamp Aiming
I had the misfortune of having both lenses on my 98 GP fall off and I replaced one about three years ago and the other this past summer. I happened to park in the driveway with the garage door closed and noticed that the right lamp is way higher than the left one. Since both were replaced with used ones from the wrecker, I don't know which one, if either, is accurate. Can anyone tell me what the correct height should be and which screw is used to make the adjustment?
proscroby is offline   Reply With Quote
Old 10-29-2010, 07:32 PM   #2
BNaylor
BNaylor's Avatar
Re: Headlamp Aiming
I guess there were no takers on this one. Are you referring to the physical mounting of the headlamps on the header panel/front frame or adjustment of the beams?
Timeslip 08/12/06
AF Community Guidelines
BNaylor is offline   Reply With Quote
Old 10-29-2010, 09:05 PM   #3
proscroby
proscroby's Avatar
Re: Headlamp Aiming
I am referring to adjusting the beams.
Old 10-29-2010, 09:23 PM   #4
BNaylor
BNaylor's Avatar
Re: Headlamp Aiming
See the old thread (posts 3 and 4) below which should help. Aiming procedure and covers the star adjusters on the headlamp assemblies.
Click here
Timeslip 08/12/06
Old 10-30-2010, 08:27 PM   #5
proscroby
proscroby's Avatar
Re: Headlamp Aiming
Once again you have come to my rescue! I had to go to an industrial area to get the space (25') and a relatively flat surface but I think it worked. They look the same to me now. Thanks again Bob.
how to change Turn signal, headlamp Glenja '97+ 1 02-05-2010 04:04 AM
Headlamps / DRL flickering umfindi Malibu 2 03-29-2009 03:08 PM
01 mpv headlamp aiming fraser4701 MPV 0 06-15-2007 11:32 AM
Headlamp Aiming specs Gems Impala | Impala SS 1 03-18-2006 03:37 PM
Does anyone make a one-piece headlamp for 88-91 Civic hatches? Or a plastic headlamp? Maryland90Hatch '88 - '91 Civic | CRX | Wagon | Shuttlee 5 06-02-2002 10:15 PM
