Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 08-17-2010, 05:25 PM   #1
benhiers
Tahoe AC problem
have a ac problem on a 98 tahoe 5.7.the ac clutch is not engaging.system charge is good.the ac has 3 switches the one on the accumulator(low pressure switch?) has 12v at switch.I tried jumping switch clutch still wont engage.the switch on the block on back of compressor(high side switch?)12v at this switch,tried jumping it clutch still wont engage.the switch on back of compressor itself(clutch cycling switch?)no votlage to this switch,even tried jumping it.clutch still wouldnt engage.have swapped ac relay with another one.help please.........
benhiers is offline   Reply With Quote
Old 08-18-2010, 09:37 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
Re: Tahoe AC problem
Auto or regular ac controls?
First thing check all fuses.
What is the charge pressure readings?
Jumper the clutch and see if it kicks in.
Let us know what that does?
Are the switches 3 wire or two wire?
MT
Old 08-18-2010, 12:32 PM   #3
brcidd
brcidd's Avatar
Switch on rear of compressor is HPCO..normally closed
The switch on the manifold block at compressor is for recirc door activation when head pressure rises too high- does not affect compressor operation.
Have you tried bumping clutch with hammer handle?, if clutch engages, your air gap between clutch driver and pulley is too wide ad needs to be pressed on to a width of .020"
if above result is negagtive, then:
Jump the a/c relay- this will tell you if problem is an input or output issue...if clutch engages, you have input issues, if no engagement, you have a wiring issue at compressor or bad coil on compressor--jump 12v battery hot directly to compressor to determine if coil is good.....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
brcidd is offline   Reply With Quote
Old 08-18-2010, 01:24 PM   #4
benhiers
system is regular ac controls
all switches are 2 wire
all fuses are good
not sure about pressures but ac will work for about 15 minutes when it has set for awhile(like 4 or 5 hours)but once clutch kicks out it never kicks back in.
I have put 12 volts on compressor and it kicks in and cools good.I have not jumped relay but did replace replace it with a know good relay.I will try jumping relay tonight.the switches are 2 wire switches.the wires at HPCO switch dont have any power. Also there isnt any power at the clutch.I have put 12 volts to wire at HPCO switch and it works good.where does HPCO wire get its voltage from?thought about running a jumper wire to wire at HPCO switch and leaving it but not sure if it will hurt compressor or cause ac to freeze up???
thanks guys
Old 08-18-2010, 04:53 PM   #5
MT-2500
AF - Advisor
MT-2500's Avatar
all fuses are good
thanks guys
The light green wire on HPCO switch goes to the ac switch in HVAC control module.
Make sure as switch is switching on threw the light green wire.
MT
Old 08-18-2010, 07:26 PM   #6
benhiers
is the HVAC control module the switch panel thats in the dash??where you turn on and adjust ac/heat?
Old 08-18-2010, 11:16 PM   #7
Cookiebaggs
This forum might help if you can't get it figured out w/ advice here.
http://www.autoacforum.com/categories.cfm?catid=2
Cookiebaggs is offline   Reply With Quote
Old 08-19-2010, 04:29 PM   #8
MT-2500
AF - Advisor
MT-2500's Avatar
Sorry about late answer internet down here.
Yes it is.
No on connector B light green wire feeds AC switch on signal to low pressure cut out switch.
From Low pressure cut out switch dark green/white feeds to VCM engine computer connector c3 pin 25.
From vcm connector c2 pin 3 dark green/white connector c2 pin 3 dark green/white to ac compressor relay B6 dark green/white wire.
If switching ac request there and relay has power on A4 pin pink wire ign mini fuse and orange wire B4 ac compressor fuse.
Your clutch should turn on.
MT
Old 08-19-2010, 04:41 PM   #9
MT-2500
AF - Advisor
MT-2500's Avatar
Caution some control circuits to relays are ground controlled.
If some do not have 12 volts switching on them check for grounding control.Looks like the AC clutch relay may be one of them with ground control.
Let us know what you find.
If all else fails get a.
http://www.alldata.com/products/diy/index.html
MT
Old 08-19-2010, 04:53 PM   #10
MT-2500
AF - Advisor
MT-2500's Avatar
For finding ground control snd ground circuits.
Lise part no 24550 makes a computer safe double light test light.
Green light is neg ground and red light is pos circuit.
Or you can reverse a computer safe test light to find ground circuit.
But be sure to always use computer safe test light on and computer circuit.
MT
Old 08-20-2010, 06:57 PM   #11
benhiers
ok I think its the hvac control module.I was checking wiring on back of it and when you hit ac will work for a little while.when it stop hit again and ac will come back on.so for now I just run an ign hot wire to light green wire on HPCO switch.will get a module next week.
Old 08-21-2010, 09:31 AM   #12
MT-2500
AF - Advisor
MT-2500's Avatar
If you are going to use it jumper ed always run it threw a fuse and be careful where you are jumping into circuit as some circuits are ground circuits and computer low voltage circuits.
Good Luck and let us know how it goes.
MT
Old 08-21-2010, 11:33 PM   #13
benhiers
thanks.I run it through the safe side of a ign hot wire,will post once I get a havc module and let you if that was the problem
Old 08-22-2010, 11:18 AM   #14
j cAT
since you fed the clutch with 12volts , at the compressor and it did not pull in I suspect that the clutch coil is defective. since this is an old vehicle replace the compressor...use new or a scrap yard part.
sometimes coils when they fail,,, slowly loose the ability to create a strong magnetic field. this is due to the windings shorting out. as the temperature increases so does the resistance. then there is insuffient magnetism to pull the clutch in after a period of time...
Old 08-22-2010, 09:30 PM   #15
benhiers
I put power to the hot side of the hpco switch and the clutch did pull in.the problem is Im not getting power to the hot side of the hpco switch
