Go Back   Automotive Forums .com Car Chat > Chevrolet > Caprice
Old 08-03-2010, 01:14 AM   #1
brad1087
caprice rear end swap
Hi I've got a 92 caprice with the 350 and the 8.5" 10 bolt rear end. It has basically been nuked and is time for for swap. I'm curious as to wether or not the rear end out of a 94 roadmaster would fit and if not which ones would. I know the sub models based their year from 91-93 and 93-96 but I'm not sure how interchangable the rears are. Any help would be greatly appreciated.
brad1087 is offline   Reply With Quote
Old 08-03-2010, 03:42 AM   #2
silicon212
Confoundingly Lucid
silicon212's Avatar
Send a message via ICQ to silicon212
Re: caprice rear end swap
I'll put it this way: I have a 1988 and it has the rear axle out of a '94 9C1 (disc brakes). It was plug-and-play, direct swap. The only change necessary on my end was the parking brake setup which is a little different with the discs.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
silicon212 is offline   Reply With Quote
Old 08-03-2010, 08:36 PM   #3
96capricemgr
The Roady rear should be a perfect fit. It could be 2.56 or 2.93 ratio so you might have an incorrect speedo afterwards.
96 Caprice Medium Garnet Red
11.56 at 115.9mph naturally aspirated
94 Caprice wagon, rotted out POS
96capricemgr is offline   Reply With Quote
Old 08-07-2010, 01:21 AM   #4
brad1087
Thanks for the help guys you saved me a bunch of hours of frustrating research that was going nowhere.
