Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Old 07-20-2010, 02:59 AM   #1
crumpler03
idle issues
Hey guys got a little problem. I have a 99 mustang GT. Ok whenever i start my car start the car the idling is fine its a between 500 and 700. When I put the car in reverse or drive the car idling goes way down like around 200 to 400 rpm and then it builds itself back up to normal after a sec, but if i drive some it goes down until i press the gas some. Also when I drive it goes fine no problem but when I start to slow do before i make a complete stop the car has idled down to 500 already and when i make a complete stop it goes lower like it wants to cut off. I do have a exhaust leak but thats not been an issue it all started after i fixed my speedometer with a programmer. Could someone please help me out here. email me @ [email protected] or just reply to this please. Really need to fix this issue
crumpler03 is offline   Reply With Quote
Old 07-20-2010, 10:22 AM   #2
Blue)(Fusion
Blue)(Fusion's Avatar
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: idle issues
Your Idle Air Control (IAC) Valve is a likely culprit. It is on the back of your intake plenum. It is held on by 2 10mm bolts and has a small air intake tube going to it, so should be easy to spot and remove.
Some have success with cleaning it with carb cleaner, but usually ends up being only a temporary solution if it fixes it at all. You can get a replacement from your dealership or get a Duralast part at Autozone for about $80. I got a Duralast one and it has worked well so far for over a year and a half. It also came with a lifetime warranty which is a plus.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Blue)(Fusion is offline   Reply With Quote
