Go Back   Automotive Forums .com Car Chat > Oldsmobile > Bravada
Old 06-12-2008, 11:43 PM   #1
justinb10
Rear Hatch not working.
When I press the rear hatch button under the rear wiper switch, nothing happens. I can hear the noise it makes as if it wants to unlatch the hatch, but it does not open. The vehicle is in park. On the remote, when I press the button twice, it does the same thing. It will make the noise like it wants to open up, but won't.
Any ideas as to why?
The whole gate opens without a problem, just not the glass itself.
2007 Pontiac G6
2000 Oldsmobile Bravada
1998 Pontiac Grand Prix GT
2002 Ford F-150
2007 Ford F-150
1993 Chrysler New Yorker Salon
justinb10 is offline   Reply With Quote
Old 06-16-2008, 11:00 AM   #2
ZL1power69
GM S-Series Mod
ZL1power69's Avatar
Re: Rear Hatch not working.
This has been covered a few times. What usually happens is the plastic part of the actuator that connects to the hatch release mechanism brakes off. The actuator will still work but the glass will not open. Its an easier fix on a four door. Raise the rear gate and take off the entire plastic interior panel. You should have access to the actuator. Either fab up a metal piece to connect the actuator to the linkage or buy the updated actuator from gm for about $70.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
ZL1power69 is offline   Reply With Quote
The Following User Says Thank You to ZL1power69 For This Useful Post:
ericn1300 (09-17-2015)
Old 09-14-2015, 12:04 PM   #3
beir
old dog learnin new trick
beir's Avatar
Had same problem..took rear cover off..ended up being dirty mechanism..used pb blaster and is working fine now
beir is offline   Reply With Quote
