Go Back   Automotive Forums .com Car Chat > Dodge > Caravan | Voyager
Old 06-20-2010, 04:56 PM   #1
ftamike
Lack of power 2001 T&C 3.3L
Hi i have noticed that my minivan has lost power especially going up hill has 101k on it and had i recent tune up can some one please assist me with this problem and i also checked to see if i have any code ,but no codes thanks
"I think Congressmen should wear uniforms like NASCAR drivers so we could
identify their corporate sponsors."
ftamike is offline   Reply With Quote
Old 06-22-2010, 07:59 PM   #2
RIP
AF -Advisor
RIP's Avatar
Re: Lack of power 2001 T&C 3.3L
How long between the tune up and lack of power? What did the tune up consist of?
Weak fuel pump? Connect a pressure gauge at the fuel rail. Should see a steady 55 psi. Lack of power at speed is one indication. Sag or stumble on acceleration is another.
Timing off? It has to be checked with a capable scanner. If you want to throw parts at it an upstream O2 sensor would be high on my list. A sliped timing chain on these engines is nearly unheard of but not out of the question.
Uniforms? Great idea!
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
RIP is offline   Reply With Quote
Old 06-23-2010, 12:24 AM   #3
ftamike
[quote=RIP;6520908]How long between the tune up and lack of power? What did the tune up consist of?
Changed plugs , wires, thermostat and 02 sensor the one on the exhaust before cat
Old 06-29-2010, 01:50 AM   #4
soyelmismotony
Smile Re: Lack of power 2001 T&C 3.3L
next to battery the are some plugs that can be moved specially if you disconected the Battery look for loose plugs especially the bottom one cam and crank shaft and position sensor signals can be lost it the bottom conector is loose. if connector looks ok. test the cam shaft sensor. if van runs fine at idel and on flat surface but only up hill is the problem the fireing order is out of timing if sensor is sending wrong info due to a sensor malfuntion or loose conector hope this helps. i had cam and crank shaft position sensor problems that got solved by replacing both of them and tide that loose conector. on my 98 caravan 3.8l
soyelmismotony is offline   Reply With Quote
Old 06-29-2010, 06:11 PM   #5
ftamike
i will give it a try thanks
Old 07-18-2010, 05:57 PM   #6
saveualot_123
men mine is a runs and sounds like a sick mower no power blakc smoke i don't know whats going on i need some help with ideas replaces spark plugs ang run the van for less than 19 min took the spark plugs out they had black soot all over them please help
saveualot_123 is offline   Reply With Quote
Old 07-19-2010, 01:51 AM   #7
RIP
AF -Advisor
RIP's Avatar
Model year and engine? In general the list of possibilities is long. Have you checked for codes? Any recent maintenance. Did this come on slowly or without warning?
Old 07-19-2010, 09:01 AM   #8
saveualot_123
Unhappy Re: Lack of power 2001 T&C 3.3L
1992 dodge caravan 3.3 engine.no codes no chech engine light,took the air filter out it sucks more air in and at the throttle body there is a sensor that its under neath that bypass air when the throttle body is shut.if i close this hole using my finger like half way the van idles fine i have changed it already without any luck so am guessing something else which i don't know am backed againist the wall out of ideas
Old 07-19-2010, 01:46 PM   #9
RIP
AF -Advisor
RIP's Avatar
I may or may not have the right picture of your finger test but in any case you are regulating air by doing it. Leads me to think - vacuum leak. My fuzzy logic? If you have a leak anywhere upstream of the intake manifold gasket, covering the IAC hole with your finger will decrease the loss of overall vacuum making the engine run better especially at idle. Is the EGR valve stuck open? All the vacuum lines in good shape? Intake manifold gasket good? It's called the Idle Air Control Valve or IAC valve.
