Go Back   Automotive Forums .com Car Chat > Pontiac > Trans Sport
Old 09-28-2009, 03:06 PM   #1
iceman2
1997 TP 3.4 L Odor of anti-freeze
Have a 1997 TP with 3.4L, 165k miles, second engine. The add coolant light flashes and I can smell anti-freeze. Mechanic who replaced the engine claimed to put new upper/lower intake manifold gaskets in when he replaced the engine in April 2007. The excess coolant tank needs to be replenished about once a month - about a pint, but the stench of anti-freeze is quite prominent,
thanks. The temperature gauge is solid, does not fluctuate.
iceman2 is offline   Reply With Quote
Old 09-28-2009, 07:13 PM   #2
Jrs3800
Re: 1997 TP 3.4 L Odor of anti-freeze
The smell of antifreeze is inside the van? If so this could be a heater core problem..
You don't by chance see any coolant on the ground at any time do you?
Jrs3800 is offline   Reply With Quote
Old 09-29-2009, 05:45 AM   #3
iceman2
No I do not smell AF inside the van and have not noticed any on the ground.
Old 10-13-2009, 10:52 PM   #4
96tsport
Sounds like a small leak onto something hot & then burning off. Could be any one of the rubber hoses where they clamp on. Have a close look at whatever you can under the hood with the engine at operating temps.
~70k last 3 years with no major issues ~270k total; unknown prior history.
96tsport is offline   Reply With Quote
Old 07-05-2010, 03:06 PM   #5
deerefeed
I had a similar condition with little coolant loss. It was the rad cap leaking under pressure. I didn't locate it until I used a stop leak additive and it sprayed all over the top of the rad around the cap. A new rad cap solved the problem and I had the cooling system flushed and refilled. A neighbourhood mechanic was convinced it was the back head gasket leaking since he has replaced so many of them.
deerefeed is offline   Reply With Quote
