Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 04-13-2010, 10:59 AM
RallyEclipse98 RallyEclipse98 is offline
Send a message via MSN to RallyEclipse98
Arrow I need to install a new fuel filter...
Well I have no clue when the last time the 98 had a new fuel filter in it. I know for sure not in the last 25,000 miles. So I bought a baldwin filter but don't know how to put it in. I will try to find a how to article but any help from you guys would be greatly appreciated. Thanks.
"Staging in the Dodge lane is a Talon, or Eclipse, or Plymouth, or Mitsubishi... Ok, I don't know what the hell it is, but it'll be turbocharged and it's going to school this Mustang." - Announcer at a track
DSM power.
Old 04-13-2010, 12:23 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: I need to install a new fuel filter...
GM filters usually have either a quick connect fitting or a threaded fitting. I have found a 16mm and a 20mm wrench work well for the threaded fittings. If it has a quick connect fitting with the white plastic tangs pinch the tangs and slide off the fitting. If it has a black plastic cap on the quick connect push the black plastic piece towards the line to release the quick connect.
Old 04-13-2010, 09:15 PM
Thanks, that will be useful once I find out where the thing is. Ha, do you have to take out the backseat to get to it?
DSM power.
Old 04-13-2010, 10:06 PM
Airjer_'s Avatar
should be under the car near the fuel tank.
Old 04-13-2010, 10:25 PM
Do I need to access it through the wheel well or through the backseat?
DSM power.
Old 04-14-2010, 01:02 AM
Airjer_'s Avatar
You'll need to safely jack up the car and look underneath
Old 04-14-2010, 09:32 AM
Thanks. I'll report back once I've done the job.
DSM power.
Old 06-30-2010, 07:31 PM
dreager dreager is offline
It''s in front of the right rear wheel-well at the sill...easy access.
1999 Buick Century Custom 3.1L , 148,000km. 2000 Toyota Echo, 1.5L 220,000km
