Go Back   Automotive Forums .com Car Chat > Ford > Econoline
Old 04-19-2010, 08:09 PM   #1
Pleasuremann
My electric windows won't respond..
Some of you saw my previous threads about the hood in my 86 e150 and the rust problem. Well thanks in part to your help those are now things of the past. But now I have a new problem to tackle.
Around 6 months ago, my window triggers on the driver and passenger side stopped working. I remember being able to push the little console hard against the door panel and sometimes the driver's window would roll, but now nothing is responding.
My passenger side window was completely down when the problem occurred, so it has been down since then, and this is of course a problem.
I have taken the door panel off of the passenger side, and all screws with the exception of the bundle of wires holding the electric console in place. I get about 6'' of clearance so I have a good look at the wiring, but no idea about how to identify the problem and rectify it.
I manually pushed up the passenger window to protect against weather and it's staying up...but I don't know if there's a problem with the arm, the motor, or the wiring. Any of you guys have experience in this?
Pleasuremann is offline   Reply With Quote
Old 04-19-2010, 08:16 PM   #2
mechanic1980
Re: My electric windows won't respond..
most likely the switches on the drivers side you can get them at a yard or part store its one assembly the first in line it feeds the other window without a wire diagram you can check the motors with 2 jumper wires just unpklug + to 1 side - to the other and swap one goes up one goes down if that makes sense to you
mechanic1980 is offline   Reply With Quote
The Following User Says Thank You to mechanic1980 For This Useful Post:
abstractcamera (08-21-2018)
Old 04-19-2010, 08:26 PM   #3
Pleasuremann
First off, thank you for responding to my problem. Now, I'm sure what you have said makes perfect sense in your head, but what I read was really unintelligible. Again thank you, but if you intend for me to understand you, perhaps you could be a bit more organized in your approach.
