View Single Post
Old 04-19-2007, 09:58 AM
reekor reekor is offline
Re: 1992 crown vic prclems
Try pulling the parking brake up by hand see if the light turns off. If that does not work there is a switch at the top of the parking brake pedal that might be stuck. Also check you brake fluid level these cars did come with a brake fluid level sensor that can trigger the light. If you do find the brake fluid level low check for leaks as pressure loss from a leaking line will also trigger the light.
Originally Posted by tank7725
Ok i need help. I have a problem with the brake light on my crown vic. It is on constantly. The parking brake isn't stuck on. I was wondering if this year was made with brake pad sensors or what might be the prob
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
