Changing my timing belt
4GZChatch
04-24-2003, 12:34 AM
Hey all,
I am changing the timing belt in my 94 accord in the very near future. I just wondered if any of you have already done it, and if there are any hangups that I should watch out for. Also, are there any other things that I ought to do while I'm in there? Please let me know!
Oh, and do the H series motors use a balancing shaft?
Thanks guys!
Thanks guys!
kaoru-tochiro
04-24-2003, 09:47 AM
make sure that the tension pulley gets bolted down real tight and use thread lock, a bunch of people I know had problems with ripping t-belts when they didthe job themselves!:cool:
dutchaccord
04-24-2003, 04:34 PM
i did a lil searchng for u and this is what i found;
http://www.cybertrails.com/~puf/Honda2.2/997Honda2.2TimeBalNote.html
GOOD LUCK
Stefan
and yes they do also have a balance belt
GOOD LUCK
Stefan
guaynabo89
04-29-2003, 01:20 AM
Change the water pump and maybe the belt tensioners if they don't give enough pull. You might want to check the camshaft and crank seals to make sure they are not leaking.
