99 s-10 airbag
devyn339
03-25-2010, 11:57 AM
does anyone know how to remove the passenger side airbag also need the steps on how to re insert the new ones without them blowing up thanks alott
MT-2500
03-25-2010, 01:59 PM
Welcome to AF
When working with air bags you need to thread with care.
Sir/air bags are just like a loaded shotgun with saftey off.
THEY CAN SAVE YOUR LIFE OR TAKE IT IN A SPLIT SECOND.
AIR BAG REPAIR IS BEST LEFT TO THE PROFESSIONAL.
Was the old air bag deployed?
If so system may be triggerd and may blow a new air bag when you hook it up.
If so the module may have to be replaced first if tripped.
Some can not be reset.
To replace passanger side air bag the lower dash has to come down and air bag unbolts and bolts in.
But never hook it up untill you get the SIR/air bag system checked out with a Air bag capable scanner to be sure it is safe to hook it up.
Read up on it in factory repair manual or All Data
http://www.alldata.com/products/diy/index.html
System should first be checked with a SIR/air bag cqapable scanner.
viggy58
03-25-2010, 08:50 PM
exactly as he said above!!!
i've seen one blow the second it was plugged in. the sensor in the front bumper was bad, and blew the bag immediately. not fun.
mrelmo
03-27-2010, 11:12 AM
it has never been deployed just all a sudden the light is on not even sure it is the passenger side
MT-2500
03-27-2010, 12:03 PM
If light is on Sir/air bags system will not work.
Get it put on a Air bag capable scanner to see what the problem is.
Parts places do not do air bag scanning or testing.
You will need to find a good repair shop that does.
Let us know how it goes.
devyn339
03-27-2010, 06:22 PM
ok so i wrecked my 99 s10 and both airbags deployed i got new sensors that bolton to the rad. support and a new passenger airbag and drivers side airbag ...i hooked up the airbags and connected the battery and the airbag light is on so the question is is there some sort of reset or what can i do to turn it off?????????..... also the module i didnt replace them i didnt even think about them is there olny one for behind the steering wheel or is ther one for the passenger side to aslo is could that be why the horn dosent work now to?
