09 E350 headlamp wireing need help ASAP
lngroller
03-24-2010, 04:53 PM
Ok I just bought a recovered theft E350. They cut the headlamp connectors off. The guy I bought it from put generic connectors on. Problem is Low beams are very dim, but high beams are fine. so I'm thinking that the ground is fine. Can anyone tell me what color wires go to which connector. See attachment if I have done this correctly wires listed A, B, C this is right side bulb and rounded end up. please if you have it give me wires right and left side for A, B, C
Ground and high beam wires reversed, that's why nice and bright on high but very dim on low beam, no ground for low beams.
mechanic1980
04-13-2010, 07:28 PM
BU-GN = Low beam
BK-GY = Ground
YL-VT = High beams
According to Alldata Schematic of that connector These Are the colors of the wires for your connector and what they go to
mechanic1980
04-13-2010, 07:36 PM
That is from left to right on your pic
lngroller
04-14-2010, 06:03 AM
Thank You, I thoiught I had posted yesterday that this was solved. They had switched the high beams and ground wires. I think I have everything straight on this van now.
I really appreciate your time in searching this out for me.
Dave
