95 Metro Stalled out at light
mr.Hand
03-10-2010, 04:21 PM
Like to thank you all on here for your help over the years.
my 95 metro with 215,000 miles stalled out at a light today while i was slowing for a stop.
the oil light and check engine lights came on. I turned the key to start, and it took a while to start it again, it turned over after 5 seconds, and the engine kinda revved up slowly and the warning lights went off.
what could this be?
appreciate your help
what could this be?
bennie442
03-11-2010, 01:12 PM
Your car has 215k miles on it. This is probably not what you're wanting to hear but, I think your engine may be running on low compression and needs to be rebuilt. A compression test will need to be done to know. Factory spec is 199 lb/sq. in. new, and 154 lb/sq in. low compression limit. Post back what you find.
doug7x
03-11-2010, 08:32 PM
check the fuel pump & relay
