spuddering on 04 stratus
rdem_crew
02-26-2010, 09:22 AM
Have a 04 2.7 and when you try to get going and give it gas it spudders and then takes off and( forward and reverse) when stopped the rpm's bounce between 2000 and 2700. Cleaned out throttle body. Any idea's??
ottomatic
03-04-2010, 12:44 PM
have you checked for vac. leaks?
rdem_crew
03-04-2010, 07:16 PM
I did and everything seems fine. Pulled one plug and it looked bad. Do you think it could need plugs and wires??
ottomatic
03-08-2010, 01:02 PM
Plugs and wires should not make your engine rev 2000 - 2700 rpms. sounds to me more like a vac leak. Is your check engine light on?
rdem_crew
03-15-2010, 08:20 AM
No check engin light but sometimes driving and needing to give it gas to climb a hill the check engine light flashes on and off. In my first post I meant to say that the car idles between 500-800 rpms. Thanks
ottomatic
03-15-2010, 09:44 AM
If the check engine light flashes , you should get it scanned to see if it stored any codes..
brice0829
06-30-2010, 03:52 PM
I am having same problem, were you able to get this fixed
