New Amplifier won't power up
davekes
02-22-2010, 04:50 PM
Just installed a new amplifier in my RV, running the amp and the head unit direct off the leisure battery. I am not getting power to the Amp from the Head unit Amp turn on lead. I have checked the voltage and it is -0.03 at head unit cable and -0.08 at amp terminal block. the amp feed direct from the battery is fine. Any ideas?
I am thinking about running the Amp to head unit wire direct from the amp to the battery and using an inline switch to power it on/off thus bypassing the head unit altogether and not draining the battery when not in use, Is this a good fix?
Also, I have run the Ground wire from the amp to negative terminal on the battery, Is that ok?
Thanks
Dave
PaulD
02-23-2010, 07:09 PM
are you SURE yopu are not wired to the solid blue antenna lead ? It only works when the radio is on.
