removing radio 2000 gmc jimmy
osuengr
02-03-2010, 09:07 AM
how does the dash covering around the radio come off thanks
ken_man_1
02-03-2010, 01:10 PM
The dash is easy. There are two screws that hold the plastic up where the speedo is - remove them. After that it just has spring clips holding the front "bezel" to the dash itself. Watch for the electrical connectors when pulling off the bezel - and you'll probably have to put the shifter into low range - just to get it out of the way.
Once you've accomplished that, then the radio either has screws that hold it it, or it has 2 sliding clips that holds it in. Easy peasy. :cool:
MT-2500
02-03-2010, 05:41 PM
If no screws and holding clips there will be 4 hols that you will need the 2 U shaped radio release tool.
Also take radio off off lock setting before disconnection power to it if it has the lock feature.
Good luck and let us know how it goes.
