Old 04-11-2003, 07:22 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Easier Way?
im using this utter peice of shit valve spring compressor, but i need like 5 hands to even mount the thing to my b16, and for some reason i can only get the exhuast valves off, but it takes like 30min a valve, is there an easier way to do this?
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 04-12-2003, 01:59 AM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
no its a bitch, thats why they charge u so much, just be patient
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 04-12-2003, 03:04 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
you trying to get them off right? take a socket as big around as the valve spring, and put it on top. then just whack the socket with a hammer. the clips will come off, i promise. and to put it back on after you rebuild, just use an 02 sensor socket (the kind with the slit up the side) and your spring compressor, compress it down, and using needle nose pliers put the clips back in. simple, although it does take a long time
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 04-12-2003, 03:09 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
He's got it exactly.
I just finished rebuilding a engine in school and I used a piece of pipe about a 1" high and the same diameter as the valve spring. To get the little metal clips off take a flat head screwdriver rub it on a magnet to magnatize it, then touch the clip. It should come out no problem.
Hope that helps man!
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 04-12-2003, 04:48 PM
crxlvr's Avatar
ok i havent tried the mallet method yet, but what i did was take a socket and put it in the teeth of the compressor to therotically make it longer, so after a good compress and releasing the tension on the compressor fast the retainers go flying and the whole mess starts again. i kept an old rag over the retainers so i could find them later.
but i gotta try that mallet method, seems easier.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
