Tamiya Porsche 959
Noosart
01-27-2010, 05:51 AM
Hi all, this will be my first build report on AF, so let's hope I can get you all interested ;)
I'd read this topic of the 959 and it lured my to AF.
http://www.automotiveforums.com/vbulletin/forumdisplay.php?f=1157
I'm also building this car and I've just started on the engine.
I've removed all panel lines (which were quie a lot) and dry-fitted al enqine parts.
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_13.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_14.jpg
When all fitted correctly, I started painting the aluminum parts. First in gloss black and then in Alclad Aluminum
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_17.jpg
The engine bloc will stil need a second shade of paint on the black parts in Duraluminum. The transmission and some of the suspension parts are already painted semi-gloss black.
While the paint was drying, I'd done some bodywork. Again, the panellines were removed and the rear wing received some putty and sanding. Also the side blinkers were removed and will be replaced by transparent onse later on.
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_8.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_9.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_4.jpg
Until next update.
Arno
Porsnatic
01-27-2010, 07:30 AM
Good start on this classic super car model...I will be watching this!
mn80228
01-27-2010, 10:17 AM
Good work removing those ugly panel lines at the back.
I'll be watching this one too.
I have two 959's in my display case.
Any thought on color yet?
Noosart
01-27-2010, 01:44 PM
As a matter of fact I do :)
I've though of different colours, but I think it will be Artic Silver with a medium gray interior. This was the colour setting it was presented in as a streetversion.
Red and white don't really fit this car (my opinion) and black is too... uhm, black. :rolleyes:
mn80228
01-27-2010, 07:25 PM
That's funny, the two I have are white, and Boyd's HotRod Red.
Noosart
02-04-2010, 01:49 AM
With the tips I read here, I started to detail the engine compartment and engine lid. I made some mesh for the inside of the air intake and cut some squares that will be the start of the fan housings.
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_21.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_20.jpg
Then I drilled small holes for the bolts of the different panels. I also added a small piece of styreen to fill the gap of the rear lights.
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_19.jpg
The airfilter also got some minor details. I'd already made an opening into the airfilter, but yesterday I inserted two small pieces of scrap PE to make the two vertical 'struts' in the air intake.
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_18~0.jpg
Indeed... I'm doing the small bits these days. Next were the shock adsorbers. The coil springs were caste together with the whole shock assembly. I cut off the coil springs and made new ones using iron wire.
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_19~0.jpg
The picture, unfortunately, doesn't show the impovement quite good because everything is black. But thrust me, the new shocks (below) are much better. Then I saw a flaw in the kit. The front shocks should each have 2 coil springs and not one. So those will be addressed too.
Next up where the small squares on the side skirts, which I 'made' using a panel scriber.
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_21~0.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_23.jpg
While I was scribing the small panels, I noticed that the filler cap for the fuel was sitting on the wrong side. Or was it???
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_20~0.jpg
After looking through dozens of photos, I came to the conclusion, that the 959 has 2 filler caps. One on each side.
So I scribed a second filler cap on the body.
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_22.jpg
Viccario
02-04-2010, 02:14 AM
Looking good so far! Looks like you need to do a couple of minor repairs to the RHS window frame.
Noosart
02-04-2010, 12:31 PM
That's correct. The kit was deliverd with some shipping damage, but it's easy to fix. You won't see anything once it is finished. :)
scorpiopab
02-05-2010, 05:47 AM
wow looks good..
can't wait to see the rest..
Paul.
Noosart
02-15-2010, 01:01 AM
I finished the fans for the engine hood. I also created the hinges.
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_24.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_25.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_26.jpg
Later on, I decided to cut out the trunk lid. There for I had to create a small insert, where the lid will rest on when closed.
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_33.jpg
I also had to make de air intake with the small vertical panels. The rest is finished with puty.
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_34.jpg
And finally I detailed the inside of the lid.
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_37.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_38.jpg
The inside of the trunk lid only needs to get a ring around the filler cap. And of course the entire trunk space needs to be scratched.
Arno
steve0vw
02-15-2011, 03:41 PM
Any progress on this work of art?
Deathtrap
02-16-2011, 01:23 PM
Well actually, yes there is. Forgive me that I forgot to post it, but I was very ill. I was recovering from cancer and that led to many long stops in my progress.
But now I'm healty again and I even finished the 959. Here is a quick summary of the build:
I first finished the engine:
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_39.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_40.jpg
Then I had to create the trunc space:
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_41.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_45.jpg
I also needed quite some time to figure out the brake assembly for the rear wheels. It seems that Porsche used a separate handbrake caliper. I've created one, using a white metal brake caliper.
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_43.jpg
A quick fit of the lights. You can still see a bit of puty to fill the gaps next to the lights.
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_46.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_47.jpg
And the last major stage is painting the body. After the primer coat, the car was sprayed in gloss black as a base coat:
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_50.jpg
After the base coat, the car was painted in Artic Silver from Zero Paints.
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_54.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_55.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_56.jpg
The interior also came out quite nice (in this picture the carpetting is still missing)
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_58.jpg
And when the finish line is insight, I always dryfit the whole car as a sneak review of the end result :)
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_61.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_62.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_63.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_64.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_65.jpg
The last thing I want to add are some of the problems you could run into with this kit:
The A pilar was slightly bend. Because the front window is placed from the outside, it sticks out a bit. I didn't want to put too much force on the assembled car, so I have to stick with this result:
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_71.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_72.jpg
The fans I made were nice, but didn't fit with the engine in place. The lid couldn't close anymore. I had to remove them :(
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_73.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_74.jpg
The last problem was with the exhaust system. Because the rearbumper is too thick, the exhaust forces the entire body 1mm to the front.
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_75.jpg
I didn't find a way to solve this, but hopefully you guys can learn from my mistakes.
Here is the photo shoot of the finished Porsche 959
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_76.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_77.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_78.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_79.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_80.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_81.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_91.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_82.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_83.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_84.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_85.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_86.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_87.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_88.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_90.jpg
http://albums.modelbrouwers.nl/coppermine/albums/userpics/10008/959_89.jpg
ewestra
02-18-2011, 01:24 AM
Hey Arno, nice to see on this forum to. As one Porsche-enthousiastic to an other:thumbsup:. And now hurry back to the Gemballa.
Eric
Martini Man
02-18-2011, 08:05 AM
glad to here your doing well, model looks great
about the rear wheel... i had to remove the engine side half of the two part muffler
in order to get it to fit.
rsxse240
02-18-2011, 07:01 PM
Beautiful recreation of one of (in my opinion) the BEST looking Porsches of all time.
