blown Interior dash light?
viclaster
04-11-2003, 11:35 AM
I have a question. I have recently lost lighting in my dash gauge faces in my 1998 Acura LS. I've checked the fuses under the dash, and the fuses under the hood. Do you think that it is the bulb? Is it just one bulb that lights up the entire dash gauges? Any info would be greatly appreciated.
york2600
04-13-2003, 03:48 PM
There's a lot of lights in the dash so it's gotta be a fuse. I believe that those lights would be on the interior light fuse. Mine died and the gauges stopped working. Way shitty.
-Tim
viclaster
04-14-2003, 01:00 PM
Thanks. Maybe I didn't check good enough on the fuses. I'll try again.
InTeG x Coupe
02-23-2004, 03:34 PM
well your interior gauge lights are not located under ur dash at all. its in the fuse box under ur hood next to the battery. the fuse should be marked "+B lanturns" i had the same problem =)
viclaster
02-29-2004, 01:31 AM
Thanks. I'll check that out.
