96 Bonneville won't stay started
bhontz
01-19-2010, 10:12 PM
NEED HELP!.. My step son was driving this car around with no problems.. It turned off on him. Now it will start.. But it cuts off after just seconds. I think it could be the fuel pump. I pump the gas pedal (rev it up) to TRY and keep it running, but it just cuts off. I need advice I have to many kids to count and just want to get this thing running again.. I'm a do it yourselfer and if there are several inexpensive things I could try, let me know...
Mickey#1
01-19-2010, 11:35 PM
Best test is to connect a fuel pressure gauge to the schrader valve on the fuel rail. The freebee is to check the driver's side ground bus for corrosion.
big white bufflo
01-22-2010, 09:31 PM
is there a security lite that comes on for the vat system these cars a noted for this.listenfor the pump to run before start up is the a ck engine light need more input
smbonneville
02-10-2010, 11:39 PM
could be a mass air flow sensor it happened to my bonneville just quit all of a sudden it would run when i applied the gas pedal i replaced the mass air flow sensor and fixed the problem
Jrs3800
02-17-2010, 11:25 AM
Is the Security Light on Solid?
