94 voyager dies
jkingiii
01-12-2010, 07:31 AM
I have a 94 Voyager and it starts fine, sounds good, but when I let of the gas, it dies. I was thinking the following:
1: Throttle Position Sensor
2: Idle control valve or
3: Idle air control motor
Any thoughts are greatly appreciated. I'm trying to figure it out before I just start replacing parts.
tempfixit
01-12-2010, 09:49 AM
Clean the throttle body and IAC passage way> Does it do it when cold and warm?
jkingiii
01-12-2010, 01:49 PM
I haven't tried warm, just cold.
jkingiii
01-25-2010, 07:21 AM
I've replaced the Idle control and ERG... a lot of crud.. Cleaned everything out and it still happens. When I take the vacumm hose off the ERG valve, it seems to idle better???? Any thoughts?
plymouthsrock
01-25-2010, 07:48 AM
Seems like an EGR problem. You should not be getting a vacuum signal to the EGR valve at idle. Work backwards from there- control solenoid/transducer and connections, vacuum hose routing, etc.
