2003 Taurus Dash Lights
atmk631
01-06-2010, 09:15 AM
Hi, I'm wondering if anyone has had to change any lights in their instrument panel. The bulb that lights up the fuel gauge has blown. I had a quick look under the dash yesterday and it looks near impossible to access the bulb.
Any advice would be great.
Thanks
Thanks
FordBoss88
06-03-2010, 11:11 PM
My God! This was posted in January and has yet to be responded to. Someone please answer this question.
shorod
06-04-2010, 07:44 AM
Well, go ahead an answer it then! If you don't know how to do it on a 2003, then apparently you're like several others on this forum.
If I had to venture a guess though, I'd say there are probably a couple of screws holding the lens cover/trim in place. If those screws were removed, that would yield access to more screws that hold the instrument cluster in place. Remove those and carefully wiggle the instrument cluster out far enough to disconnect the electrical connections, then remove the cluster. With the cluster out of the instrument panel the bulbs should be readily accessible.
But keep in mind, this is just a guess based on how several instrument clusters were assembled over the past several years. I would be very surprised if any of the bulbs were accessible with the cluster still in the car.
-Rod
-Rod
danielsatur
09-08-2012, 04:04 PM
2002 Ford Taurus /295K miles
Found 3-bad bulbs, I replace all 5 in the instrument cluster with LED, see http://www.youtube.com (http://www.youtube.com/watch?v=evUp2-FGjek)
Search '' Ford Taurus instrument cluster removal''.
Also see www.superbrightleds.com (http://www.superbrightleds.com) for color LED cluster replacement, they use less power + heat.
Traditional cluster bulbs can be bought cheap @ www.rockauto.com (http://www.rockauto.com)
